Complete set of Refinished Hayashi Super Street Center Lock wheels, hub adaptors, center caps, and locking wrench. Ran 3 years with no issues. Anti-seize always used on center cap threads. Wheel is rare and no longer in production.
Everything included to put into service on car.
An adaptor bolts onto your wheel hub similar to a spacer and allows you to run these Hayashi Racing centerlock rims. The Center Lock System uses a hub adaptor with conventional PCD. Once the steel adpator is bolted on, slide rim on then thread on the single alloy nut tighten using the centerlock tool (massive socket) with its breaker bar or use a massive torque wrench, tightening to 127 ft. lbs.
Period MotorSport inspired JDM wheel you don’t see at car shows.
Manufactured May1981
Bolt circle 4x114.3
Offset is +2
wheels are14x7
$1550
If PayPal add 3% for their fee
local pick up in LA or shipped at buyer’s cost
Have additional pictures I can provide.
FS: Rare Hyashi Racing Super Street Center-lock JDM Wheels
- 0B8F710D-5449-47CC-96C0-4238658F4909.jpeg (326.74 KiB) Viewed 876 times
- CEFD09B3-229E-43DB-AB9C-E341786E95E0.jpeg (536.75 KiB) Viewed 876 times
- 6FA94DEC-76F3-48A3-9DA9-FC9EBAD79611.jpeg (545.82 KiB) Viewed 876 times
- CAD5FDED-C9FF-4C1D-A3C2-B0B835A35478.jpeg (294.22 KiB) Viewed 876 times
