Wiring harnesses-- "instrument" (dash) (EDIT--lower prices)
SteveEdmonton
Post by SteveEdmonton »
I'm tired of moving the big box of these harnesses around the garage. The prices shown are about 1/3 lower than the last time I posted them, but if you still think they're too high, make me an offer. Time for this stuff to go!
This batch is “instrument” harnesses (= dash harnesses). I'm supplying parts numbers, vehicle details, and dates, where known. Where not listed, this information is unavailable.
Note: the first 2 harnesses are uncut, the last 2 have had several branches cut off. (Prices reflect this!)
Prices are in USD and shipping from Edmonton, Alberta, is extra.
#8 uncut 24013-N0900 Aug70-Jy71 sedan, 4-sp trans; comes with most/all switches, 1 connector cut/missing $100 CAD
Harness 8.JPG (123.84 KiB) Viewed 1238 times
#9 uncut 24013-N1106 Jun-Dec71 wagon, 4-sp trans; comes with 1 relay; 1 pair wires cut but present, just need to be re-joined $60
Harness 9.JPG (111.08 KiB) Viewed 1238 times
#10 cut 24013-N2205 Jan-Jn72 sedan, 4-sp trans; 4 cuts to harness (that is, 4 connectors missing) $40
Harness 10.JPG (116.04 KiB) Viewed 1238 times
#11 cut; 3 cuts to harness (that is, 3 connectors missing) $40
Harness 11.JPG (123.75 KiB) Viewed 1238 times
'71 4-door
'74 MGB-GT
'04 Miata
yenpit
Re: Wiring harnesses-- "instrument" (dash)
Post by yenpit »
Nice! For those buying, his part # off of the white tag & production dates are key, but basically 71-72 SEDAN or 71-72 Wagon are the same but had minor differences, all others are kinda listed below...........hope this makes some sense!
Buy the Paolo hand drawn wiring diagram for your car!!!!!!! I do not know of ANY aftermarket diagram that is correct ie Haynes Clymer Chiltons etc
Sedan vs Wagon ARE always different per year range, manual vs auto ARE always different per year range
This is a basic year range to follow..........
1968 only
1969 only
1970 only
1971-1972 basically the same
1973 only
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
