Need help identifying these struts
bluesbrother30
Post by bluesbrother30 »
Hello group......
I have assembled these struts to go on my vintage 510 race car. Tubes cut down, Koni inserts, adjustable spring perches, new disks. Problem is, I cant remember (old racer guy) exactly which model there were. I know they are 280's but not sure what year and model. Why?? I need to order calipers and need to know what they are to do that......if it helps, the caliper bolt holes are about 3.57 inches, center hole to center hole.
Datsun struts.JPG (100.57 KiB) Viewed 1498 times
Thanks
Mike Summers
Sacramento, Ca
Re: Need help identifying these struts
Post by datzenmike »
3.5" is 89mm which is the caliper bolt spacing for two Nissan struts. The '80-'83 S110 200sx and the '79-'83 280zx. The 280z struts were never used and they did not have the vented rotor as in your picture.
All turbo and normally aspirated 280zx years, '79-'83, were the same calipers and rotors.
You could read the part numbers off the sides of the strut tube....
