SR20DET wiring into 510
Crevier
Post by Crevier »
yeah your ''artist skill'' sucks big time lol
thanks alot again, everyone who help!
sticky???
Post by icehouse »
As long as someone re draws my "wiring diagram" :D
Crevier
Post by Crevier »
ok ok I wil redraw your diagram! and sticky it!
SMITHENGINEERED
Post by SMITHENGINEERED »
Crevier wrote:ok ok I wil redraw your diagram! and sticky it!
Thanks Guys :D
Yellowcar
Post by Yellowcar »
Anybody got a diagram for a 91 KA24DE?
Thanks
arkitekz
Post by arkitekz »
Yellowcar wrote:Anybody got a diagram for a 91 KA24DE?
Thanks
Yeah! Diagram form ka24de 91-93 would be the icing on the cake.
oregondime
Post by oregondime »
here you go, its the pinout guide for every motor japanese and ka: http://www.az240sx.org/tech/Pinout/ that link took me 2 hours to find before :)
510-Trevor
REDRAWN DIAGRAM
Post by 510-Trevor »
icehouse - here is your diagram all cleaned up.
If anyone has any changes/additions they think should be added, post them here. If there is a consensus then I will revise the drawing as required.
Thanks.
See revised sketch below.
1972 Yellow 4dr
Crevier
RE: REDRAWN DIAGRAM
Post by Crevier »
the picture doesn't work
SMITHENGINEERED
Good Work 510-Trevor much appreciated!
:D
510-Trevor
you need to click on the word 'download' . This will open the pdf file for viewiing.
1972 Yellow 4dr
Crevier
Post by Crevier »
the switch you draw isn't ''switch'' it is a relay, modify it to like my diagram symbol with correct wire to coil and contact
I say this for someone who will look at your diagram and put switch and not relay
and everything else is very good!
thanks!
510-Trevor
REVISED DIAGRAM
Here is the revised diagram.
Perhaps someone can come up with better wording for the disclaimer at the bottom of the page.
sr20det wiring diag.pdf
sr to 510 harness diagram
(49.47 KiB) Downloaded 814 times
1972 Yellow 4dr
Baz
RE: REVISED DIAGRAM
Post by Baz »
one small thing that is overlooked when wiring up an Sr is the alternator warning lamp.
solder a 100 ohm resistor across the lamp terminals. this can prevent alternator failure if the warning lamp blows.
Fuel pump is best triggered from the ecu as this will cut the pump in the event of an accident where the engine stops & the driver is unable to cut the ign.
Most after market tachs will require a pull up resistor ( about 5K) across the power/signal wire.
With early ign switches bridging the ballast bypass wire to the main ign on will do the trick.
The white 3mm sense wire on the alterator is best trigged by the ign on relay. can prevent battery going flat.
If using the original temp gauge with the SR temp sender the gauge will need recalibrating, best to replace the votage reg at the same time with a solid state unit.
doughboi916
RE: REVISED DIAGRAM
Post by doughboi916 »
will a 91 ka wire up like this? anyone want to help me with a diagram also, i would appreciate it.
