Post pics of your dime and your wheel and tire mesurments
I am looking to make a good reference guide to buying wheels and tires for the 510s. So list wheel and tire size and offset. As well tell if you have flairs and about how much it is lowered if at all. If you can, post a pic or a link to a pic. Make and model to tire and wheels would be cool too.
Thanks
Jon
Thanks
Jon
RE: Post pics of your dime and your wheel and tire mesurment
My car has 15" Riken wheels, zero offset, with Yokohama 032r's, 205 X 50 series, in the "S" compound. Hard to say how much it has been lowered, but, the front airdam, with those 23" tall tires, is about 5" off the ground. On my race tires, the car's airdam has about 3" of clearance.
Don't know what year, but they are the stock wheels from a mitsubishi starion. Not sure of the offset either. all I know is that you have to grind the inner ring of the mounting area a little to make them fit. and it's fairly tight, but with the ZX struts and 195/60/14 they fit snuggly. was lowered about 1 inch.
1985 300zx na 15x6.5 +30mm
P225/50HR15 BFGoodrich euro t/a. front needed 10mm spacer on my 200sx struts, rear on a sedan would need rear fender lips rolled and one side would need a 5mm spacer for tires this big.....these wheels will fit no problem with 195/50r15.
Denis Gagné
AKA VGwagon
69 510 VG30e swapped
73 240z VG30et swapped
AKA VGwagon
And here are 1992 300zx na 16x7.5 wheels +45 offset wrapped with 205/50r16 kelly evo-z tires....12mm spacer on front and rear will need the same on a sedan...oh and a 5-lug conversion is also needed for these. 1980 200sx struts w/1986 turbo 300zx front hubs
Denis Gagné
AKA VGwagon
AKA VGwagon
Old Style Mags Also.
1972 Stock 4 door, including suspension.
With 14x5.5" Western Bullets (? Offset) and 175/65 R14 Falken 512's
With 14x6" Enkie Compomotives (? Offset) and 195/60 R14 Falken Azenis.
Will these fit in stock fenders
Will these fit in stock fenders with it dropped? 14” x 7”
http://www.konigwheels.com/catalog_prod ... &ss_id=430
RE: Will these fit in stock fenders
i dont think they will since they only make 14x7 rewinds in -9 offset. the 0 offset 15x7 cuts really close to the fender
