New Member
New Member
I bought a 72, 510 wagon last January. Barely made it home after 3 Hour drive in traffic because of a carb linkage issue and no rear brakes. Got it home and threw it up on Jack stands. Dropped the rear end, replaced the rear brakes and rear leaf springs with a T3 spring kit. Pulled out the motor, trans, and front suspension. Purchased some T3 front 280zx struts, Adjustable LCA's. Rebuilt the front ZX Calipers and then hit a wall. Having a hard time to keep going and not get distracted with other things. Not too sure if I should tear the motor apart to see what I've got as I do not trust the previous owner with his maintenance routine. Or start cleaning up the engine bay and installing the front suspension. Hard to stay focused with ADD.
