Does anyone have a source for new / restored / alternatives for 510 windshield washer nozzles?
One of mine broke when I was disassembling.
Has anyone solved this with an off-the-shelf solution? Open to the realm’s knowledge here and would greatly appreciate your insight on solving this. Thank you!
A few options I have on my list:
1). Replace the tubing with new SS tubing and bend to proper clearances
2) Zeddsaver - Norm has them listed but they are out of stock:
https://www.zeddsaver.com/products/dats ... asher-jets
3) The 240Z washer jets “might” be feasible to modify to work. These are on ebay but $$$$
4) New Sprayer head like these -modifying the front cowl cover to mount these properly - and run plastic tube thru old sprayer holes from underneath.
https://www.amazon.com/Hypersonic-Unive ... B00MB7EXW6
5) Classic Ford Mustang Sprayers look like they could be adapted:
https://eclassics.com/eclassics-1967-19 ... ozzle-pair
Windshield Washer Nozzles - Any sources/Alternatives?
Re: Windshield Washer Nozzles - Any sources/Alternatives?
I believe I have a spare or two if you want a stock one. I think the spares are not painted or plated or anything.
I will have 510 nozzles. I might have RE-PLATED yellow zinc, but I do have raw original. The Z car can be used in a pinch, if you have access to any of those, but you would need to bend them a little to suit the 510.
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
