Bought this R160 subaru 4.11 open diff but never used it. $150? Pick up in Calgary, too heavy to ship.
A 510 stub fits the splines inside the side gears, however there are no threaded buttons inside because Subaru uses spring clips. Appears there would be space to add buttons.
If someone wants just the gear set minus the carrier and housing, and pays for shipping, no problem.
R160 Subaru 4.11:1 Diff
Re: R160 Subaru 4.11:1 Diff
FYI you can ADD the threaded collars for the 510 bolt in stub axles, because this is an OPEN diff (not LSD)..............but you must disassemble the carrier with the spider gears to install. All R160 R180 bolt in stub axle threaded collars are the same.
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
