WTB: Center console brackets & 2 door window bracket
510sports
Post by 510sports »
Am seeking the brackets to secure the center console for the 510 as my console has no support and is completely loose! I also need a bracket for one of the rear window clasps for a 2 door. Thank you
iceman510
Re: WTB: Center console brackets & 2 door window bracket
Post by iceman510 »
Which bracket and which side? They are all different.
On the body or on the 1/4 window frame?
Left (driver) or right (passenger-assuming LHD)?
510sports
Post by 510sports »
iceman510 wrote: 15 Jun 2023 05:21 Which bracket and which side? They are all different.
i've just realised both are missing, I need the on the body brackets like these:
thank you
yenpit
Post by yenpit »
I should have USED, but the chrome was so horrible from the factory, that most are oxidized! I MIGHT have a pair or re-chromed. PM if interested!
I assume your center console if for an AUTOMATIC? That console did have brackets...........I might have.
If your console is an aftermarket Amco from back in the day, they did NOT have brackets, simply screwed into the trans tunnel, thus most are broken. Let me know what you have, maybe I can help!
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
yenpit
Post by yenpit »
It sounds like you have a JDM Coupe? You need to clarify that for MANY of the parts you might be looking for, or you will end up with lots of USA spec parts that do NOT fit!!
That said, I bet these rear 1/4 window brackets are Coupe only............I would guess that the USA spec brackets will not be the correct angle for a Coupe!!??
Also, if Coupe, they came with a factory center console (none of the USA spec MANUAL cars had a factory center console), so those console brackets will be COUPE ONLY!!
1973 510 2dr
1972 521 flat bed
LOTS of 510 parts!
510sports
Post by 510sports »
yenpit wrote: 03 Jul 2023 10:05 It sounds like you have a JDM Coupe? You need to clarify that for MANY of the parts you might be looking for, or you will end up with lots of USA spec parts that do NOT fit!!
I apologize yes this is for a JDM Coupe, I wasn't aware there were so many differences :!:
yenpit
Post by yenpit »
Yes, lots of trim parts are different! Craig Ford at Tokyo-2u Export Cars in Japan has lots of Coupe parts. NOT cheap, but he has!!
1973 510 2dr
1972 521 flat bed
LOTS of 510 parts!
510sports
Post by 510sports »
yenpit wrote: 15 Jul 2023 15:07 Yes, lots of trim parts are different! Craig Ford at Tokyo-2u Export Cars in Japan has lots of Coupe parts. NOT cheap, but he has!!
i've been trying to get parts from him for over a month now, he's just been reading messages then not replying. I gave up and bought most of what I needed elsewhere but am still on the hunt for the center console brackets and window bracket that only he has....
deano510
Post by deano510 »
Are these qtr window brackets for a 2Dr Coupe or a 2Dr Sedan?
510sports
Post by 510sports »
deano510 wrote: 27 Aug 2023 09:44 Are these qtr window brackets for a 2Dr Coupe or a 2Dr Sedan?
from what i've seen they're both identical as the latches are the same
yenpit
Post by yenpit »
OK if the 1/4 window brackets ARE the same (I do NOT know & don't have the resources to verify), I will have a set of 4pcs RE-CHROMED.
I MIGHT have a set of USED, but the chrome is ALWAYS bad............thus I will have a set re-chromed.
If you only need 1pc bracket, let me know which side & which piece.........on frame or on body? Problem is, I don't want to break up a set if that is all I have, so I might have a single.........
Sorry, I won't break up my re-chromed 4pc set.
PM if interested!
TJ
1973 510 2dr
1972 521 flat bed
LOTS of 510 parts!
