FINALLY: 1/4 window latches / brackets
iceman510
Re: FINALLY: 1/4 window latches / brackets
Post by iceman510 »
Further follow up. I did in fact run into this same issue. I had selected the two best-looking latch attachments brackets I had and put them on the car. When I did the LH quarter window all went well. When I went last week to put in the RH side, it would not close down and latch. Checked the bracket and it was the same as the LH side. I had to track down the others I still had in the parts bin and find one that had the right hole location. Put it on, and everything works as it should. Lesson learned.
