Hello!
I have had the 280zx strut/brake swap in front for 20years, and now want to upgrade rear drums to discs as well.
Is 280zx rear discs/calipers still a recommended upgrade, or any reason I rather should go for Maxima or S13 240sx brakes?
I need to retain parkbrake function, it is mandatory to be road legal here.
Thanks, regards Leif
Recommended rear disc upgrade?
Re: Recommended rear disc upgrade?
I've got a pretty similar set up except I have 200sx front coilovers. I did the rear maxima conversion with the e-brake and it's working well so far. What motor are you running?
If zx you want the later '82/'82 calipers.
Here is the link to the DQ article showing a 280ZX front and rear disc swap.
https://drive.google.com/drive/folders/ ... VOsa5PeUSQ
JBC Z32 rear disc brackets. https://www.jbcoachwerks.com/shop/114-r ... n-brackets
Silvermine offers kits as well as many others manufactures. https://www.silverminemotors.com/datsun ... e-upgrades
The DQ link doesn't take you directly to the article. It's Volume 2, Issue 4.
