What are these?
eastbaysolo_73
What are these?
Post by eastbaysolo_73 »
Hey fellas,
Found these in my storage. Can some one please identify what they are and where they're mounted?I have a hunch but not sure. Are these related to seat belts? If anyone can share a photo of there location that would be great ? Im going to restore them and install them once I know where they go. Thanks in advance.. :mrgreen:
Imageimage0 2 by v p, on Flickr
My build thread
Nor Cal Meng !
WxMan
Re: What are these?
Post by WxMan »
I suspect your hunch is correct.
eastbaysolo_73
Re: What are these?
WxMan wrote: 14 Jun 2021 14:46 I suspect your hunch is correct.
Awesome ! Thanks WxMan very much appreciated. Now I have to find some screws after I clean them up.
My build thread
Nor Cal Meng !
cartel
Re: What are these?
Post by cartel »
OMG are you using stock seatbelts :roll:
:D
Mike Gibson
MikeY
Re: What are these?
Post by MikeY »
That's not a picture of stock belts.
WxMan
Re: What are these?
Post by WxMan »
It's a Datsport belt.
eastbaysolo_73
Re: What are these?
cartel wrote: 15 Jun 2021 18:34 OMG are you using stock seatbelts :roll:
:D
Im not most likely Datsport belts.
My build thread
Nor Cal Meng !
yenpit
Re: What are these?
Post by yenpit »
I will likely have the correct chrome tapered head screws if you need.
See how that aftermarket belt has a plastic "sheath" that hangs down much lower than the OEM seatbelt (they did not have a sheath)? That sheath likely won't fit into the OEM clip, so get your seat belt kit BEFORE you install those clips, unless you simply want the factory look of that clip.
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
eastbaysolo_73
Re: What are these?
yenpit wrote: 08 Jul 2021 13:15 I will likely have the correct chrome tapered head screws if you need.
Will do. I haven't installed them yet.
My build thread
Nor Cal Meng !
