Pictures readily available-- PM me your email address and I'll gladly send some.
Shipping extra, the default being Canada Post from Edmonton. Prices are in dollars, CAD = USD. Paypal or interac e-transfer work great.
NIB Nissan rear LCA mounting bushings (set of 4)-- LCA to crossmember (for a long time these were impossible to find) 75
SOLD
NIB Nissan transmission pilot bearing 10 SOLD
NIB National Oil Seal rear pinion seal 10
6-bolt 225 mm flywheel, lightened (18 lb), excellent condition 70 SOLD
5-bolt 200 mm flywheel, excellent condition 20
2 sets of 4 half-shaft bolts with washers & nuts 10 each (NOTE: previously listed as driveshaft bolts, thanks to Mike G for the correction!)
1 pair GMB U-joints made in Japan 30
steering box 20 SOLD
steering idler arm (one original Nissan brand = 15 SOLD; one aftermarket "555" brand = 10) SOLD
complete steering assembly (all the spaghetti, from side to side-- tie-rods, ball-joints, etc) 25
NIB SKF front wheel bearing set (both sides, inner & outer bearings + seals) 60 SOLD
NIB Timken rear hub seal 5
1 pair moderately used KYB Excel-G rear shocks 25
NIB clutch master cyl 5/8 (stock size) 20 SOLD
NIB Beck-Arnley clutch slave cylinder 20
NIB Nissan brake master cyl rebuild kit (for stock Nabco BMC) 10 SOLD
1 pair of brand new, never used brake master cyl reservoirs incl caps (aftermarket) 5 SOLD
1 brake system "manifold" (splitter) incl pressure-warning valve (as mounted on left strut tower) 10
3 NIB brake hoses (made in Japan) 5 each
1 set NIB Nissan brake-hose spring clips (4) + 1 new-but-stray copper washer 10 SOLD
1 pair stock front brake rotors, exc condition, 9.81 mm thick 50 SOLD
1 pair stock front brake rotors, brand-new & never used, drilled (!), 9.93 mm thick 50
1 pair front hub dust-covers, excellent condition, no dents 10 SOLD
1 pair 240Z aluminum brake drums, 1 damaged fin on 1 drum, 9.08" dia 40 SOLD
1 set NIB stock rear drum-brake hold-down cups & springs 5
2 NIB Beck-Arnley rear drum-brake adjusters (didn't these go NLA a while ago?) 15 each SOLD
NIB Nabco drum-brake cylinder 13/16 (stock) 10
NIB SY drum-brake cylinder 13/16 (stock) 8
1 pair NIB NAPA Premium 280ZX front brake rotors 30 SOLD
1 set NIB Axxiss 280ZX front brake pads 15
NIB NAPA 280ZX left front brake caliper 60 SOLD
2 Centric 280 ZX brake caliper rebuild kits 5 each SOLD
complete rear disk-brake setup, 1983 280 ZX (calipers, rotors) 60 SOLD
1 pair CNC alloy adapter plates (from The 510 Factory) for 280 ZX rear disks, brand new, never used, 100 SOLD
1 Lokar e-brake cable kit (2-to-1 cable + all hardware) for use with 280 ZX rear disks, brand new, never used 100 SOLD
1 set of 4 poly TC rod bushings #7020, used but excellent condition 15
NIB set of poly front LCA bushings, Energy Suspension 20 SOLD
NIB set of 2 Energy Suspension polyurethane Mac Strut bump-stop bushings 10 SOLD
stock mustache bar, excellent condition, bushing size = 50mm 20
NIB set of 4 Energy Suspension polyurethane mustache-bar bushings, 40mm OD 20
complete set of rear cross-member-to-body mounting pieces, incl. washers, studs, rubber pieces 20 SOLD
2 pairs front sway-bar brackets, good condition 10
1 pair front sway-bar links with poly bushings, very gently used / excellent condition 20
Driveline, suspension, & chassis parts for sale
- SteveEdmonton
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
Re: Driveline, suspension, & chassis parts for sale
sent list
Mike Gibson
Yer like a parts store!!
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
- SteveEdmonton
Haha-- I think I could say the same about you! I think we both enjoy helping guys "keep em on the road."
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- andrew.lori
I have to agree with TJ and Steve. Your both a great source for bits and pieces.
1966 Sunbeam Tiger MK1A
1970 Datsun 510 KA24DE
1973 Toyota Celica
1972 Triumph GT6 SCCA Vintage Race Car
1974 Mazda RX3 former IMSA race car
1973 Toyota Celica
- SteveEdmonton
Added items:
Pair of rear LCAs, left and right, including stub axles & backing plates, excellent condition, minimal surface rust only, 60 each SOLD
TC rod for front suspension, right side only, very good condition, no visible damage, 20
Front LCA, left side only, excellent condition, minimal surface rust only, 25
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- SteveEdmonton
And yes a few more added items (though I think this is "it" for this section). Pics available by email on request.
200mm clutch pressure plate, brand-new, bolted on but never used (I used a Roadster PP instead) 25
clutch forks-- 5 for use with non-adjustable pushrod; 1 for use with adjustable pushrod (with hold for spring) (SOLD) 10 each
NIB Beck-Arnley 280ZX transmission-to-crossmember mount (steel/rubber) 10
2 brand-new Nissan clutch-fork dust grommets (1 NIB) 8 each ONE SOLD
several sets of 6 flywheel bolts in very good condition (misc sizes) 10 per set
--26mm long, with 5 mm unthreaded shank
--26mm long, with 7 mm unthreaded shank
--28mm long, with 5 mm unthreaded shank
--28mm long, with 7 mm unthreaded shank
--31mm long, with 13mm unthreaded shank
speedo drive gears & carriers (misc sizes) 10 each
--17 tooth, short carrier
--16 tooth, long carrier
--17 tooth, long carrier (2 of these)
--18 tooth, cog and shaft only (no carrier)
throw-out bearing collars (misc sizes) 10 each
--26 mm long, for 200mm clutch (for 510, to 7/73) (2 of these available) ONE SOLD
--34 mm long, for 200mm clutch (I think), 1973-1979 (I think)
--39 mm long, for 200 mm clutch (I think), from 8/81 (OR for 225 mm clutch, from 12/74)
6 transmission switches (to activate backup lights, etc.) 5 each (two SOLD)
1 stub axle, complete with inner & outer sections & spacer tube 20
NIB stock rear brake shoes (Wagner) 20
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
- SteveEdmonton
Sometimes a picture helps...
Flywheel bolts-- see earlier post in this thread for size differences-- $10 / each set of 6 Clutch-fork grommet, NIB, Nissan-- $8 each (2 available) ONE SOLD Speedo-gear carriers-- see earlier post in this thread for # of teeth-- $10 each Throwout bearing collars-- see earlier post in this thread for sizes-- $10 each Pressure plate-- 200mm clutch, never used, brand new-- $25 NIB brake shoes, Wagner Premium-- $20
- IMG_8832 comp.jpg (159.25 KiB) Viewed 1455 times
'71 4-door
'74 MGB-GT
'04 Miata
'74 MGB-GT
'04 Miata
Hi Steve, I am in Edmonton too, sent a PM, message me please.
