My '72 wagon has a problem. The clutch does not disengage. It used to, but after sitting in a humid spot for a year or two, it doesn't.
I confirmed that the slave is working. I tried starting it with the clutch in and the brakes on, to see if it would break free. No.
Before I pull the trans, am I overlooking anything? It it reasonable to think that the clutch material could fuse to the flywheel?
Thanks!
Stuck Clutch
Stuck Clutch
- P1010681.JPG (161.5 KiB) Viewed 1827 times
1972 2-door, 4 door, wagon, wagon.
Re: Stuck Clutch
usually you can hold the clutch down and try and start it with the brakes on and it will free up. or start it in gear drive it around while engaging and disengaging the clutch and it will pop free.
Re: Stuck Clutch
Use the starter. If e brake won't hold, push car up against a solid masonry wall. Put in high gear hold clutch down, bump starter repeatedly.
Clutch disc is stuck to either the flywheel or the pressure plate.
Re: Stuck Clutch
First warm up your engine. one way that may work would have you jack up the rear of car (please use jack stands) and start in third gear. hold down clutch and get some wheel speed going with some on off brake application. If rusted clutch it should brake free. If not same thing can be done on a paved road IE third gear clutch in on and off the gas. Its all about high torque load with clutch in!
Re: Stuck Clutch
I'd pull the rubber boot on the clutch arm and with a good flashlight have a look to make sure that just maybe some how the throw out bearings sleeve didn't fall of the end of the input shafts cover or that piece didn't break somehow.
Re: Stuck Clutch
Update: It warmed up to 36 today, so I took the trans out. It just wasn't possible for me to drive the car, so I did it the old-fashioned way. It motivated me to make a trans attachment for my jack, so that's a good thing. And I found a $4 Dorman clutch alignment tool in town (#14501)
The clutch plate was stuck to the pressure plate. One whack with the dead-blow freed it. I used a red scuff to knock off the rust, and put it back together. Also dealt with the corrosion on the push rod for the throw-out lever, greasing it. Should be good to go for a long while.
Thanks again!
Thanks again!
Re: Stuck Clutch
I lightly grease (white lithium chassis grease) the throw out collar, the clips and contact points on the clutch arm and the collar, the pivot ball on the transmission and the dimple on the clutch arm where the push rod contacts. If you have the adjustable kind, that one too.
Re: Stuck Clutch
Very nice Goonbystickel wrote: ↑30 Oct 2020 12:53 My '72 wagon has a problem. The clutch does not disengage. It used to, but after sitting in a humid spot for a year or two, it doesn't.
Thanks!
