Door and 1/4 black window pinch weld
eastbaysolo_73
Post by eastbaysolo_73 »
Sup fellas what are you guys using for replacements? Mine are pretty bad shape and would like to change them out.
Thanks in advance.
My build thread
Nor Cal Meng !
slowerthantime
Re: Door and 1/4 black window pinch weld
Post by slowerthantime »
There are the ones I got from Datsport. Haven't installed them but they look good.
eastbaysolo_73
Wow I wasn't aware they sold those. I have most of the rubber on my car from them. Thanks I didn't even think to look.. Gonna give Baz and email. Thanks.
My build thread
Nor Cal Meng !
duke
Post by duke »
Mcmaster also sells stuff that is very similar to the stock edge trim. The pattern isn't exactly the same, but it still looks the part.
https://www.mcmaster.com/edge-trim/rubber-trim-6/
eastbaysolo_73
duke wrote: 23 Jun 2020 06:32 Mcmaster also sells stuff that is very similar to the stock edge trim. The pattern isn't exactly the same, but it still looks the part.
Thanks Duke already placed an order with Datsport. There was a few other thing I needed from them as well.
My build thread
Nor Cal Meng !
iceman510
Post by iceman510 »
slowerthantime wrote: 22 Jun 2020 14:09 There are the ones I got from Datsport. Haven't installed them but they look good.
I am getting ready to order some Datsport stuff. Are those displayed in the same order in all the pictures? The smooth lower one is the quarter window? The top one has the surface grain more closely matching the original. I don't want some smooth and some not like those appear to be.
Thanks.
slowerthantime
The smoother one with the large opening is for the door.
Colbino
Post by Colbino »
I think I have a factory set with the metal corner thingys that I'd could possibly part with.
