Dual 44mm Mikunis on a L20B question.
I was wondering if you were running dual 40mm Mikunis on a stock L20B driven on the street would you have to run an electric fuel pump or will the stock one work fine?
Re: Dual 44mm Mikunis on a L20B question.
You should have no problem with either. Many people running dual sidedrafts - weber and mikunis- using the stock fuel pump.
I ran a mechanical - dont think it was stock, but was never able to dig up any info on it - on my old L20b with hot cam and Mikuni 44s.
My guess is electronic fuel pump might deliver a more consistent feed of fuel... but also is one more thing to break or go wrong...
You would need to run a low pressure electronic pump and probably ideal to run a regulator to - Mikunis are pretty particular about fuel pressure - ideally between 3.5-4.5 psi. I am running the a Carter low pressure pump with a Holley low pressure regulator on my current Mikuni set up - Ive got an inline gauge in there too, mostly for setting the pressure initially, but now just to keep an eye on it.
You can certainly run either. I ran twin side drafts for years on stock type mechanical pumps in daily drivers.
If going mechanical, try to utilize the later L20B pumps from 78-80. These are higher volume - but not higher pressure. These pumps also seems to work better when high under hood temps weer causing problems with fuel boiling - a problem I had on one of may DD comunter cars years ago.
Also, if you can find a quality fuel pressure regulator and take the line pressure down to 2.5 to 3 spi - your needle and seats onthe carbs would love you for it.
Otherwise, you're good to go.
Thanks for the info everyone.
