I hit a pretty large milestone this weekend. All structural and mechanical work is now done. There may be some small modifications down the road, but the truck is physically pretty much done and I'm down to electrical, interior trimming, and some small body pieces.
- CabBedMounted.jpg (98.55 KiB) Viewed 651 times
First, I finally got the cab and bed mounted for the final time. Pretty much everything fit nice, the bed mounts needed some bolt-hole enlargement to shift it a bit to the right, but I'm pleased how it sits.
- RearWindowMounted.jpg (85.26 KiB) Viewed 651 times
With that done I decided to add the rear and door glass. The rear glass mounted ok, some of the rubber still need a bit of messaging on the corners but I'll wait until it's spring to work it better.
- WindowFeltAdhesive.jpg (89.63 KiB) Viewed 651 times
Before mounting the door glass I installed some generic window felt. Overall it fit nice and was a pretty simple process with the door cards out of the way.
- SecurityWarning.jpg (83.73 KiB) Viewed 651 times
Next the door glass was installed. I got a chuckle from the security 'warning' that came with my truck. I'd like to lightly tint the windows but want to find a way to preserve this sticker.
- LicencePlateLights.jpg (147.07 KiB) Viewed 651 times
Now it's a bunch of little thing that I notice are missing as I work the area. In this case the licence plate lights were non-existent. I ordered some cheap plate-mount ones - we'll see how long they last. I do like how subtle they are.
- LicencePlateLightsMounted.jpg (81.91 KiB) Viewed 651 times
I've also got main power/ground run and into the cab. The most cost effective solution was to purchase heavy duty jumper cables. 1GA in this case with a disconnect, $75 CAD or so on sale from princess auto.
- MainBatteryCables.jpg (122.99 KiB) Viewed 651 times
I wanted something small and efficient for main fuse and read some positive reviews on the Blue Sea terminal/fuse. This 300A fuse is tiny!
- 300ABlueSeaFuse.jpg (58.29 KiB) Viewed 651 times
It mounts on proprietary (5191) terminal which neatly hangs off the side of the battery.
- BlueSea5191FuseBlockTerminal.jpg (68.93 KiB) Viewed 651 times
Next up is the electrical. I've already got the lines run, the starter and alternator wired up, so I'm maybe 30% done? I've got a long weekend coming up and the weather continues to cooperate, so I'm hoping to get most of the major stuff done and take the truck for a quick spin this coming Sunday.
After that I'll finish the interior, install the windshield, then take my time to finish up the small non-critical stuff like electrical vents, gauge cluster (make the Speedhut gauge fit a little better in the 620 dash). I'm well on my way to getting this truck registered in March or April.
I can say that after 3 years of slaving away on this build, it really is surreal to be at this point, and super FUN!
