Door wont open stuck closed.
Re: Door wont open stuck closed.
all the action happens on the other side of the latch assembly
- eastbaysolo_73
Ok guys just got my car back from my buddys exhaust shop. Thanks for all the comments and input. I tried doing what some of you posted and it still does not work. My car is a 1970. Im not sure if the door mechanism is from a 69 or 70. But either way I tried and here I am in the same spot.. Gonna try some more today as the air is actually breathable air today here in Pleasanton CA.
Door lock by v p, on Flickr
My build thread
Nor Cal Meng !
My build thread
Nor Cal Meng !
Ugh. I should have most latch parts if you need anything.eastbaysolo_73 wrote: ↑07 Sep 2020 12:03 Looks like I'm gonna use my dremel tool and have to cut it inside the door close to where it goes through the hole inside the door and makes contact with the striker to get the door open. Every thing I've tried doesn't work. Sheesh the most annoying shit ever.
TJ
1973 510 2dr
1972 521 flat bed
1972 510 Wagon parts car
2009 Toyota Matrix S AWD
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
- eastbaysolo_73
Thanks Yenpit
My build thread
Nor Cal Meng !
My build thread
Nor Cal Meng !
- eastbaysolo_73
Got the door open!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thank god. Unfortunately I had to use the dremel. No damage to the door or inside of the door. But the mechanism will need to be replaced.
My build thread
Nor Cal Meng !
My build thread
Nor Cal Meng !
I think the difference between early & late is the engineering of the rotating latch mechanism, cuz I have seen two different styles, but I'm thinking they are interchangeable..........?? Can you post a pic of the BACK of the latch, where the rotating latch mechanism & spring are? I likely have either way, let me know!
1973 510 2dr
1972 521 flat bed
LOTS of 510 parts!
1972 521 flat bed
LOTS of 510 parts!
