Page 1 of 1
Motor mount question
Posted: 14 Apr 2018 19:16
by bluesbrother30
Hi group.........
So my car has been apart for some time.........there are two distinctly different motor mounts. One is a one piece stamped unit. The other has a couple pieces factory welded together........are they the same height?? Which side does the multi piece go on?? Passenger, driver??? Help !!!!
Mike
Re: Motor mount question
Posted: 14 Apr 2018 21:26
by datzenmike
The single engine bracket is on the left the other on the right.
The rubber isolaters are the same.
Posted: 15 Apr 2018 09:01
by James
Passenger or Driver might be more clear...
Posted: 15 Apr 2018 09:31
by datzenmike
Depends where you are. Imagine sitting in the vehicle. left is to the left, right to the right.... it's universal, can't go wrong. In Australia, Japan and other countries the passenger side would be to the left so that would be confusing to those readers. I might say 'single engine bracket is on the right side as viewed from the front' but it takes longer. It's definitely on the left side of the car.
Posted: 15 Apr 2018 17:37
by bluesbrother30
- Datsun (2).JPG (27.16 KiB) Viewed 6382 times
Another question........is the pic of this motor mount in the correct position?? Or do I have it upside down??
Mike
Posted: 15 Apr 2018 19:55
by RMS
that would be upside down. if your using that aftermarket mount you will have to fight to get them lined up. there's a post about how much thicker that aftermarket mount is.
Posted: 15 Apr 2018 20:24
by bluesbrother30
Yup you are right there........these are aftermarket and I have spent a hour just moving them around to different angles and bolt combos.........they just are not going to work as is. Is there a link to the discussion or just type in motor mounts in the search box.
Posted: 17 Apr 2018 20:43
by datzenmike
Try just starting all the bolts and leave loose. Same with the engine brackets.
Posted: 18 Apr 2018 03:27
by 68Datsun510
Ive gone through the same ordeal, where on earth they got that spec for thickness is beyond me.
Posted: 19 Apr 2018 06:23
by abisel
Get the OEM mounts from here:
https://www.nissanpartsdeal.com/parts/n ... &Filter=()
Item 1 in this picture:
- Capture.JPG (87.4 KiB) Viewed 6260 times
I have also found that the motor mounts for an L20B raise the engine a bit to high for my liking. Whereas the L16 motor mounts which are a bit thinner, work just fine.
Also, be aware that the mounts to the engine block themselves (items 2 and 3) are LH and RH.
Cheers,
Posted: 30 May 2018 10:40
by Hakosuka510
68Datsun510 wrote: ↑18 Apr 2018 03:27
It's because they're Chinese manufacturers who happened to spec the mounts off the 620 Datsun because most people
think they're identical to 510 mounts when in fact the 620 are 3mm(?) taller.
620 owners actually have a huge break though in that, from that point onward, Nissan retained that mount thickness for virtually everything, including the SR20, and the face of the mounts where they meet the block brackets have the studs and alignment nubs in the identical position. Only the back plates that bolt to the crossmembers are different. This means as a 620 owner I'm able to take Kazama or Cusco SR20 engine mounts, take them apart, cut the S-chassis mounting plate off and weld an original 620 plate from an old, failed mount (using a Japanese one, as the Chinese ones are made using the thinnest plate they can get away with) on, and suddenly I have the most amazing engine mounts ever. UNFORTUNATELY, it won't work for my 510 because of the height difference...
Posted: 31 May 2018 02:59
by 68Datsun510
Makes sense... Im trying to figure out a better mount option for my VG swap, but nobody makes z31 upgrades... UGH lol
Posted: 31 May 2018 14:28
by Hakosuka510
68Datsun510 wrote: ↑31 May 2018 02:59
Whiteline makes some that don't look
bad. Also, Z31 mounts look verrry close to S13 mounts. What's the thickness/height of yours?
Posted: 11 Jun 2018 02:31
by 68Datsun510
Stock appears to be 2 3/4", z31 mounts
