Saw some on Amazon, they seem like a great idea. I'm not sure which version is the right one to fit our Datsun master cylinders, but it would appear this is a pretty good idea. I'd sure love to pour a couple quarts in the pressure tank, pump it up, then just walk around and let each bleeder go till it runs clean and bubble free.
These things work?
Anyone use a pressure bleeder?
Re: Anyone use a pressure bleeder?
For that kind of money I'd look for a good pressure/vacuum pump that will work for lots of things and not just BMC tops.
I have a vacuum system with bleeder accessory. I'm tired of running back to the front to refill the stupid cylinder, which I always forget.
I suppose I could use an old master cap and rig up some kind of pressure vessel for a do it yourself version, see how it works.
With a pressure/vac version, you could attach the reservoir bottle and push fluid through the bleeders at the calipers/drums.
Made this for bleeding the clutch system on my Audi. Bled from the bottom up and it required 0 pumps.
Sorry, I owe a bit more explanation. That's just a pistol grip oil can I got at my FLAPS for ~$10. I attached a piece of hose to the end and use the can to fill the hose before I attach it to the bleed nipple. Crack the nipple and pump to your hearts content making sure you don't overflow the master or run an air bubble into the system with the pump. Close bleeder and remove the hose. Enjoy your quick bleed job.
For me this didn't require anymore bleeding but it could change for different systems. I have yet to try this on my 510 or 240.
Motivation came from YouTube. Skip to the ~4:50 mark.
https://www.youtube.com/watch?v=wdf--suwqw0
I've been fighting a soft pedal issue for a week now, finally crossed the street to a mech shop to have them pressure bleed it. Couldn't access the master ports due to the pressure plate needed for dual master. No air out of calipers, still soft pedal. Took it home and 4 hours later bled the master and got a cloud out of each, which slightly stiffened the pedal. In summary, if you get the chance to pressure bleed, try your hardest to access the master first. My 2€. Trades humor...
'69 2dr KA24DET
