- Front shot
- image.jpg (686.61 KiB) Viewed 4273 times
Project Z32
Project Z32
So it's been 4 months since I bought my donor.... I planned on stripping the car down complete....the challenge began with removing everything off the unibody.....in the first week I removed these items....front bumper,headlights,radiator,fenders,door panels,doors.....within 2 weeks I was planning out the next move on removing the vehicle harness.....after that I was unbolting stuff.....such as front suspension ..arms....brakes etc.....then I had a pause cause I needed to figure how to cut this car up .and leave the motor and tranny intacked.....more pics to come
Re: Project Z32
Interio removed,wiring harness and ecu removed
- Interior shot
- image.jpg (350.71 KiB) Viewed 4254 times
- Front shot2
- image.jpg (695.09 KiB) Viewed 4254 times
Re: Project Z32
So what is wrong with the car that your cutting it up and are you doing the DE in a 510 Dave Lum swap?
Re: Project Z32
Double post?
okayfine wrote:Are you swapping in the VG30DE? If so, big project. Lemme help:
DQ Volume 1 Issue 2 - VG30DE Installation Guide : Part One - Does your 510 need more power? How about the twin-cam V6 out of the latest Z Car.
DQ Volume 1 Issue 3 - VG30DE Install Guide: Part Two - Does your 510 need more power? How about the twin-cam V6 out of the latest Z car.
DQ Volume 2 Issue 1 - VG30DE Installation Guide: Part Three - In this installment, we'll look at what is involved in getting the engine ready to run, including oil pan, intake and exhaust, cooling system, wiring, and fuel-system modifications.
Re: Project Z32
The car was in an accident that damaged only the right rear wheel assembly....seller had it sitting for almost a year befor posting it on craigslist....I have a good friend that has z32 also....so we went halves on this one. He gets all body parts,trims,complete interior...minus steering wheel(mine)
Okayfine thanks!!!!! All help is good help!,,,
Re: Project Z32
Cutting z32s tail light assembly,spare tire well,removing as tank ,cutting off rear vent glass quarters,cut off floor pan,cut off front windshield,unbolt crossmember from frame,unbolt transmissions mounts.....and lift off....now that's all that's left
- image.jpg (614.76 KiB) Viewed 4160 times
- image.jpg (631.86 KiB) Viewed 4160 times
- image.jpg (589.62 KiB) Viewed 4160 times
- image.jpg (623.88 KiB) Viewed 4160 times
- image.jpg (621.31 KiB) Viewed 4160 times
- image.jpg (618.47 KiB) Viewed 4160 times
- 3
- image.jpg (614.89 KiB) Viewed 4160 times
- 2
- image.jpg (564.02 KiB) Viewed 4160 times
- 1
- image.jpg (682.16 KiB) Viewed 4160 times
- Gonna cut this in 1 piece
- image.jpg (640.52 KiB) Viewed 4160 times
Re: Project Z32
Just motor and trans
- image.jpg (677.13 KiB) Viewed 4159 times
- image.jpg (549.98 KiB) Viewed 4159 times
- image.jpg (647.19 KiB) Viewed 4159 times
- image.jpg (626.67 KiB) Viewed 4159 times
- image.jpg (648.94 KiB) Viewed 4159 times
- image.jpg (645.39 KiB) Viewed 4159 times
Re: Project Z32
Chassis gone,engine harness removed,now I can see all that awaits me....removing the plenum....removing the smaller cooling lines underneath,then the fun begins.....there's so much corrosion on the valve covers that I couldn't leave it alone.so now I have the plenum off I think I'm gonna start deleting all unnecessary bolt holes and give it bath before I start polishing....my original plan was to spend most my time mocking up motor mounts and engine mounts....but seeing all that.......just gave me the reason to polish out some parts and try doin a wire tuck,.....will post picks of the plenum before.during and after...
Re: Project Z32
That looks like some fun sawzalling .... .... are you going to weld in the Z32 firewall and tranny tunnel???
Re: Project Z32
Indy510....No more like using it as a template.....I went through 1pack Milwaukee blades
