Building a Morgan 3-Wheeler Replica
Current Pictures
Post by okayfine »
No problem. Took it out to run some errands to the Post Office and such, and cruised the undeveloped commercial area. Usually there are semi trailers parked all over; I wanted to drive under one and get a picture. No trailers at all, so I took a few exterior shots since I don't really have any that aren't in my garage.
Also shot some drive-by video, that'll be up in a few.
Re: Building a Morgan 3-Wheeler Replica
Post by okayfine »
One more.
Mattndew76
Post by Mattndew76 »
The trike looks great!
Custom Machined covers for the engine would look good ;)
PoorMtnKid
Post by PoorMtnKid »
It looks awesome out there! Whats the plan for the rear fiberglass cover?
Post by okayfine »
HA! Maybe so. I'd have to send you a pair so you could take the measurements. AFAIK it's dry inside, just the timing belt running around. Probably don't want to drive around without it, but...
Drive-by vid seemed good in my head, but I ended up driving by too quickly to really be able to see it. Next time.
https://www.youtube.com/watch?v=IPWz6bF ... q-JJZcCxMQ
Post by okayfine »
PoorMtnKid wrote:Whats the plan for the rear fiberglass cover?
Once I get Whitebird sorted, the plan is to make a stiffening rib on the underside, coat it with the kitty hair filler, then sand smooth and paint. I was using it as motivation to get my 510 running again, but I might just cut to the quick and get the shell done. It would mean I could also get rid of the huge foam mold that's still kicking around my garage (keeping it so I can put the shell on it when I do the exterior filler/sanding work).
duke
Post by duke »
Looking very cool, but that engine is screaming for a pair of Weber down drafts!
Post by Byron510 »
duke wrote:Looking very cool, but that engine is screaming for a pair of Weber down drafts!
My thoughts exactly - IDA's would not only look cool - they's sound awesome!
:D
Post by okayfine »
I've started to look into it. Building a manifold would be easy. Saw a picture of a V4 engine with four velocity stacks sitting up top and proud, really looked awesome. Just a matter of money...
iniazy
Post by iniazy »
Julian that's so awesome. This machine is a beauty. Congratulations.
hang_510
Post by hang_510 »
looks much better in the sunlight!
you know you want to build a manifold for it
Post by okayfine »
hang_510 wrote:you know you want to build a manifold for it
Of course, it's the $1000 in carbs and linkage and jets that are currently stopping me. :mrgreen:
Thaine
Post by Thaine »
I see you got it up and running. Bring it over to RGR. We would love to see it.
Thaine
Post by okayfine »
Hello Thaine! If I ever make it out that way I will definitely drop by!
Post by okayfine »
Got tired of the bare FG rear shell. Bent up a 3/16" round rod and added four 8" wide strips of FG to the underneath to stiffen the shape. The added FG strips probably did more than the steel rod, but the end result seems to work alright. Then covered the exterior in Bondo, sanded most of it off, then patched again, sanded again, then gave up and primed/painted it.
Looks not bad in the picture. Just stand 10' from it and you'll continue to think so. Still, looks tons better with the blue than bare FG, so whatev.
Added a decal, and then one on the front:
Took it out for some more errands, including dropping off the L-series starter to the USPS. Had some guy at Big 5 tell me about what I can only assume was a Carver he drove in Euroland. Did have a bit of a hot-start issue where it didn't want to catch. Didn't seem hot when I shut it down, and I did manage to get it started again after about a minute so... Not sure how much I want to delve into the carbs. I did try to balance them last week, and it seems to run fine under power, but it coughs a bit at steady-state cruise before it's fully warmed.
Still a blast, though.
