Ventura County Low-Key Fun Run, Aug./Sept. 2013 (see Pg. 13)
Re: Ventura County Low-Key Fun Run, 1/26/13 (see Pg. 6)
I think I'm in - depending on kids sports.
amwalker wrote: I'd like to stick with that if no one has a serious problem with waking up early.
add me to the list as a def maybe
i have to fix the 4runner this weekend and then i can get to the sedan...
if finished, ill be there!
hang_510 wrote:if finished, ill be there!
Shortened the struts and have the springs in hand, just waiting on the coilover hardware from T3. Apparently the Saturday Fed-Ex driver can't get on-base...turds.finn wrote: if you need a hand just let me know.
71 510: 4-Door, KA swap, Work in progress (Race)
bummer. sounds like your making progress though. won't be taking the dime to work on monday?
'69 2dr KA24DET
I have at least one spare to every suspension part on the car, so I modded the spare struts. All is well, I don't like downtime either.
Need some shortened ones myself... Want to cut mine down for some Adam lol...
Sure, don't you have a coilover set-up already? Just need to pick up shorter inserts for more travel?
Yup that's all I need is shorter inserts.. anyone want to buy some illuminas lol
With the weight on the front end it's time to step up to a set of custom-valved Bilsteins or a 8610- model Koni. I hadn't shortened a set before, but it was easy, bring it on.
What do you mean all that weight.... KA24de =388 lbs
3800 series ii = 392 lbs
SR20det is like 370's ?????
I've never seen rock-solid engine weight numbers. They're all educated guesses, and for all that still not terribly accurate.
yeah your right... those number were just the more quoted ones i've seen. and wikipedia so you know its right.... lol
I forgot what spring rate you had in the front...what was it?
5 days.
