SR20DET Motor Mount for Datsun, (620 Pickup)?
Hey how's it going, just looking to see what year motor mounts I should order for my Datsun to finish up my swap. I've been looking on ebay and to my surprise there are many different ones. Before I order, which year or maybe even part number would you guys recommend? And yes, I've searched.
- PoorMtnKid
Re: SR20DET Motor Mount for Datsun, (620 Pickup)?
I used 620 mounts from a 78 if I recall correctly. However mine did not mount up perfectly when using the vg30 transmission mount. Because using that mount I had to extend where the motor mounts bolt to the crossmember about 1.5 inches.
You can see what I had to do here.
viewtopic.php?f=3&t=15796&start=180
Mckinney has some mounts that are around 100 bucks. If I had not already purchased my 620 I would have gone with those ones because they are beefier and adjustable.
- andrew.lori
I used Mckinney and they worked very good well worth the $100.00
1966 Sunbeam Tiger MK1A
1970 Datsun 510 KA24DE
1973 Toyota Celica
1972 Triumph GT6 SCCA Vintage Race Car
1974 Mazda RX3 former IMSA race car
1973 Toyota Celica
'67 1600 Roadster
'68 4-door 510
'68 4-door 510
I forgot to mention I own a '73 Datsun 510
i have stock 510 mounts but i made a 1/2 inch spacer that raised the mount. my oil pan is 1/2 inch above the x member.
