The White Sloth Project
Re: The White Sloth Project
- 36.jpg (86.82 KiB) Viewed 4301 times
- 33.jpg (99.76 KiB) Viewed 4301 times
- 34.jpg (79.53 KiB) Viewed 4301 times
Haha, yes, Pioneer's can power anything!two_68_510s wrote:Looks like a speaker!Colbino wrote:Starting with a speaker? I don't get it. Thanks for the compliment though.James wrote:good work! Are you starting that engine with a speaker????
The POR does a pretty nice job of self leveling itself, so even though it was applied as if I was painting a house like Daniel-san it ends up smooth in the end. Of course you can also spray it on once diluted, but in tight areas and lack of space I felt I needed more control, specially with nasty, sticky shit such as POR.
- 44.jpg (62.72 KiB) Viewed 4298 times
- 109.jpg (112.71 KiB) Viewed 4298 times
- 110.jpg (74.29 KiB) Viewed 4298 times
The flash causes the POR to appear streaky and inconsistent but I assure you it's not.
- 113.jpg (101.09 KiB) Viewed 4298 times
- 111.jpg (123.13 KiB) Viewed 4298 times
- 116.jpg (79.04 KiB) Viewed 4298 times
With the car's floors now completely re-protected I could move back onto the body.
P.S. Some of my photos are out of sequence.
- 94.jpg (74.97 KiB) Viewed 4297 times
- 73.jpg (82.59 KiB) Viewed 4297 times
- 71.jpg (98.56 KiB) Viewed 4297 times
- 83.jpg (84.15 KiB) Viewed 4296 times
- 72.jpg (80.28 KiB) Viewed 4296 times
- 75.jpg (70.25 KiB) Viewed 4296 times
More body work...
- 10.jpg (167.29 KiB) Viewed 4289 times
Received a goody in the mail today...
- 12.jpg (93.11 KiB) Viewed 4288 times
- 16.jpg (90.68 KiB) Viewed 4288 times
- 18.jpg (90.46 KiB) Viewed 4288 times
Sanding, Filling, Priming, Sanding...Sanding...Sanding...
- 21.jpg (92.66 KiB) Viewed 4287 times
- 20.jpg (124.98 KiB) Viewed 4287 times
- 19.jpg (85.74 KiB) Viewed 4287 times
- 31.jpg (55.48 KiB) Viewed 4286 times
- 8.jpg (131.85 KiB) Viewed 4286 times
- 7.jpg (82.39 KiB) Viewed 4286 times
Driver side dents removed...
- 50.jpg (79.64 KiB) Viewed 4284 times
- 41.jpg (47.68 KiB) Viewed 4284 times
Since the car was originally White I wanted to keep it stock, but with the lack of a body/trim vin system I figured it doesn't truly matter as there isn't a coded plate to adhere to. I ended up choosing a Datsun 2-stage OEM color called Ivory White 904. I would've had this sprayed by my body/paint guy, but the plan was to get the Engine Bay done and get the motor rebuilt and back into the car ASAP. I wanted to drive the car to the paint shop instead of having it towed. Plus I didn't want to hinder my forward progress while I saved for paint/body work.
- 135.jpg (65.08 KiB) Viewed 4279 times
- 140.jpg (73.83 KiB) Viewed 4279 times
- 141.jpg (70.17 KiB) Viewed 4279 times
Steering box refresh. Before and after...
Removed the thick oil/grease from inside the box using gravity and then a pump. Purchased an OEM plug, removed all the old paint, cleaned, primed and painted with some high-heat black paint since the box resides so close to the exhaust manifold.
- 238.jpg (78.97 KiB) Viewed 4276 times
- 117.jpg (105 KiB) Viewed 4276 times
Back to the motor...
Before I got into this project the previous owner stated the engine needed the Head gasket replaced - no problem. I was under the assumption that the motor was a basic L20b with the U67 open chambered head. Anyway, I was thinking that I would just rebuild the motor with L18 dished pistons or Flat tops and toss an A87 Peanut head on it with a cam. But after removing the Head that all changed.
- 102.jpg (115.03 KiB) Viewed 4275 times
- 137.jpg (106.72 KiB) Viewed 4275 times
- 124.jpg (67.63 KiB) Viewed 4275 times
Yes, those are Venolia domed 87mm pistons. A pleasant surprise I might add. Ok, so now I was curious about the rest of the set up. Upon further inspection I found hidden within the manual that the old owner gave me a cam spec .sheet for a Nismo L7 cam shaft. You can't always rely on shit you find in the car, specially when the car is 40+ years old. I went and checked the number on the cam and it was in fact the L7 cam (or at least the Isky version of it, but I believe that Isky was the company that made the Nismo parts back then) as it had written on the end of the cam. The Valve springs were off white in color, which we know isn't stock and the Head had been de-shrouded. Cool!
- 150.jpg (53.2 KiB) Viewed 4270 times
