Molasses for rust removal
Posted: 05 May 2012 07:07
Community Forum dedicated to the PL510
https://www.the510realm.com/
Heat and penetraiting oil is really all you need and is what I used in `96 as my wipers were also seized. Today they are great, when I grease them I apply a bit of heat then touch grease to the shaft and the grease immediately thins and flows towards the hot spot lubeing inside the shaft so you don't have to take things apart risking damage. But you do need to dismount the shafts assembly from it's holding via 3 nuts, I put wax on those to keep them from corrosion.iceD wrote:I got some molasses and some vinegar today and I am going to try to free up my wipers which are seized.
ice D
