Datsun-credible!
Datsun-credible!
Here is my 1972 2 door project! I picked it up after it had been sitting for 6 years with a blown out rear spring cup. I thought it didn't have too much rust... but... the more I pull off to repair, the more rust I find!
- How I got it after I fixed the rear LCA
- img_0557.jpg (59.07 KiB) Viewed 8421 times
- That big rusty bit in the side is a big ol bit of bondo that fell off several years ago!
- img_0552.jpg (57.21 KiB) Viewed 8421 times
Tallis
Re: Datsun-credible!
shit is that the SDSS mechanics shop?!? awesome!
Wow good on you for being brave enough to tackle that one! I drove by it daily and thought about buying it for a parts car but couldn't find any part of it that didn't need attention....would love to see it during and after the fabricating and welding process!
Hey guys, yup SDSS auto shop! those pics were taken in about November, and I've done a bunch to it since, just have to post the pics (soon!) And yeah, it needs a bunch of work, but it fires up and runs really nice!
Tallis
More pics...
- If you paint the spring a sporty color it makes it perform better, right! :)
- img_0485.jpg (66.31 KiB) Viewed 8323 times
- New arm painted and poly bushed
- img_0483.jpg (66 KiB) Viewed 8323 times
- rusted out spring bucket, fun.
- img_0767-1.jpg (79.28 KiB) Viewed 8323 times
Tallis
and more!
- Interiors nice though
- img_0773.jpg (13.41 KiB) Viewed 8321 times
- Fixing up the other side
- img_0537.jpg (61.96 KiB) Viewed 8321 times
- brakes back on...
- img_0505.jpg (73.61 KiB) Viewed 8321 times
Tallis
After wanting a 510 since high school, I couldn't resist when this one came up for sale! I got a great deal on it, even with all the rust, it was a local car and very well maintained mechanically. I only had to charge the battery and replace the fuel pump and filter and she started right up. Cool. But sooooooooooooo much rust! oh well, time is 'cheap'.
- 510 strut being de-hatted
- img_0611.jpg (67.49 KiB) Viewed 8313 times
- 280ZX ready to be de-hatted
- img_0612.jpg (64.56 KiB) Viewed 8313 times
- Grinding the weld off
- img_0615.jpg (64.67 KiB) Viewed 8313 times
Tallis
280ZX front strut swap, I've cut the front springs for kicks and giggles, but will run Specialty Engineering lowering springs when funds magically appear I lowered the spring hat about an inch to get nice and low and I've got Tokico adjustable inserts to put in as well.
- Comparison shot between stock 510 and modified 280ZX with a lowered hat (about 1 inch)
- img_0620.jpg (75.55 KiB) Viewed 8306 times
- Old 280zx vs 'new' 280zx/510
- img_0635.jpg (63.84 KiB) Viewed 8306 times
- Finished front strut
- img_0659.jpg (76.42 KiB) Viewed 8306 times
Tallis
I built a new exhaust, 2", and modilfied the collector where it comes off the manifold. I'm not sure if it'll work, but cutting out the restrictions to get more flow seemed like a good plan. We'll see how it turns out when its on the road.
- Bendy, bendy...
- img_0740.jpg (80.3 KiB) Viewed 8280 times
- Mmmm new pipe!
- img_0759.jpg (61.7 KiB) Viewed 8280 times
- I've been saving this tip for many years, I think it works quite well here!
- img_0766.jpg (14.43 KiB) Viewed 8280 times
Tallis
Cut cut, weld, weld, weld, more weld...
- The offending bit removed...
- img_0743.jpg (65.54 KiB) Viewed 8279 times
- That's better
- img_0741.jpg (58.67 KiB) Viewed 8279 times
- 'Flow helpers' tacked in
- img_0746.jpg (66 KiB) Viewed 8279 times
Tallis
Then it gets finished!
- Ah, flow!
- img_0745.jpg (60.28 KiB) Viewed 8269 times
- welded.
- img_0748.jpg (58.53 KiB) Viewed 8269 times
- All welded, just need to clean up the ends
- img_0749.jpg (55.63 KiB) Viewed 8269 times
Tallis
And the biggest job for me is fixing the upper frame rails. They are both kinda terrible! But... that means I get to hone/develop my metal fab skills.
- I had 100% success while removing this fender, breaking all the fender bolts that is.
- img_0667.jpg (78.72 KiB) Viewed 8268 times
- There should be more metal than this right!
- img_0671.jpg (71.66 KiB) Viewed 8268 times
- I plasma cut this off. Easy off, but it was a pain to weld back on.
- img_0673.jpg (61.54 KiB) Viewed 8268 times
Tallis
- two_68_510s
That is some rust!
Amazing courage going after this one, but, it is only metal!
Great job. Nice to see it come back.
Thanks, there sure is a lot to practice on, but up here in BC it's wet a lot of the time. Wonderful breeding ground for rust.
on with the fender fixin...
- Sticking the new metal in...
- img_0780.jpg (73.9 KiB) Viewed 8252 times
- img_0782.jpg (76.89 KiB) Viewed 8252 times
- POR 15'd and mostly finished
- img_0783.jpg (72.53 KiB) Viewed 8252 times
Tallis
I get to fill some floor holes too!
- Seems I've got a hole in the floor, and hang on...isn't there supposed to be another pedal there on the left!?!?!
- img_0677.jpg (72.24 KiB) Viewed 8250 times
- From the top, and yes, the footprint gas pedal does make it go faster!
- img_0794.jpg (72.76 KiB) Viewed 8250 times
- From the bottom
- img_0793.jpg (81.98 KiB) Viewed 8250 times
Tallis
