http://www.zcar.com/70-83_tech_discussi ... 228.0.html
taking this sketch for part #, the inner GRW-116 is 1.25" inner & 2.75" outer, width .6875.. outer GRW-117 width is 8646" with same diameters..
so i am wondering if the stock 280z stuff is 32mm?? and it has a bigger hub than 510 too.. 62mm vs 70mm..
link shows a pretty detailed tutorial on how to change out wheel bearings too..
510 Stubs.. buh bye..
Re: 510 Stubs.. buh bye..
The 280z stubs have 27 splines vs the stock 510 25 spline stub axle (the bearings are the same size so I think they are physically the same size less the spline count and companion flanges). I have 280z stub axles to install once I break the stock 510 units.
Ive been running low 12's this year with a personal best of 12.07 @ 124 with the stock outer stubs, halfshafts, and r160 LSD.
Here is a vid of the 12.07 so you can get an idea of how I launch the car:
http://www.youtube.com/watch?v=lrSU3Qaf ... r_embedded
Side note:
I did break an outer stub last year clicking off much slower times. I raised the ride height so the halfshafts are straigt under load, changed the tires to nitto nt01 225's, and used a stiffer rear coilover spring (250lb) to help (In my mind) prevent wheel hop.
These changes in addition to a fresh diff fluid change probably helped everything stay together for multiple passes this year.
-Colton
Side note:
-Colton
found any alternative to the mw? I cant see paying $3500 either....
