problems with my lights, help!
About a month ago, my highs stopped working.. and whenever i would turn them on the headlights would turn off as well. Now, my tail lights stopped working, (brakes and turn signals still work just not the running lights). where am i starting? my fuses are new, new bulbs. relays? where would they be? thanks for the help
Re: problems with my lights, help!
Did you soak the complete fuse block assy. in a vinegar solution? This can fix numerous problems.
I had the same problem but not the brake lights too it was the old headlight relay that was worn out changed it and lights worked good as new...chongmang wrote:About a month ago, my highs stopped working.. and whenever i would turn them on the headlights would turn off as well.
I second the vinegar bath its worth a shot510wizard wrote:Did you soak the complete fuse block assy. in a vinegar solution? This can fix numerous problems.
i would turn them on the headlights would turn off as well. Really you mean when you put on HIGHbeam all the lights go out?
Most likely the relay. Pull out the relay(by the fuse box behind strut tower) pull cap off by bending the tabs and clean the contack area with sandpaper. should work.
chongmang wrote:About a month ago, my highs stopped working.. and whenever i would turn them on the headlights would turn off as well. Now, my tail lights stopped working, (brakes and turn signals still work just not the running lights). where am i starting? my fuses are new, new bulbs. relays? where would they be? thanks for the help
Headlight relay seems to be working (clicking) but power to the lamps is not. Likely the contacts inside are corroded or one of the Red/White wires is loose, off or corroded. Briefly placing a jumper wire across the two Red/White wires should give you all four head lamps lit to show that the wiring and lamps are good.
Tail lights not working? Do the fronts work? If the fronts are working then the switch and fuse is fine as the same circuit feed front and back lamps. Is the license lamp working? If it is, but the tail lights are not, then the ground for them is bad... the license lamp has it's own separate ground.
