Post a pic of your Dime.
Posted: Jun 27, 2003 - 11:12 PM
wtf wrote:
5teN wrote:
Cool pics Greg. I think we'd all like to see your 510 at an event soon!
Heres the wagon...
...You know lordco colour matches paint for like $20.
hey, no dissin' primer, D00D.
hopefully, my dime will be sporting some too.
"primer makes it cool"
My dime was kewl as hell when I got it then...
- Tee dump.... Otherside was worse.
- Picture 028.jpg (123.02 KiB) Viewed 8945 times
very.
so what happened to Lordco color matching....your car's no that color?
richard norrish
thank you, that definatly clears up any questions!GREG510 wrote:rnorrish,Pic of the air dam.It a Specialty Engineering one
richard norrish
My dime
Well here is my beeeeeeauttty, she's a bit away, greg i emailed you before bout some specs on your l20b, i can tell you that it's in the shop right now with some 280zx flattops being bored out, the only thing that really scares me is the damn front end............
- Im000513.jpg (91.73 KiB) Viewed 8885 times
...As it should.SundanceKid wrote:Well here is my beeeeeeauttty, she's a bit away, greg i emailed you before bout some specs on your l20b, i can tell you that it's in the shop right now with some 280zx flattops being bored out, the only thing that really scares me is the damn front end............
You're sure that's the only bit that took the impact ?
holla
Yes toby it is, and it's not all that bad, 400 to straighted the front end out (frame rail mostly) and then get a new front end off my blue car welded on, my dad did a good job drillin gall the spot welds. Before we get the front done though we need to replace the two rockers($1000) so when they put it on the machine to get it streched they have somethign to clamp on to. Then we need to sand and paint and get some decent fenders.....
Hey Sundance(logan):SundanceKid wrote:Yes toby it is, and it's not all that bad, 400 to straighted the front end out (frame rail mostly) and then get a new front end off my blue car welded on, my dad did a good job drillin gall the spot welds. Before we get the front done though we need to replace the two rockers($1000) so when they put it on the machine to get it streched they have somethign to clamp on to. Then we need to sand and paint and get some decent fenders.....
With the front end like that ,it will be easy to put the motor back in
Re: holla
The blue 'un and yellowy both need their fair share of work, however bluey doesn't need a new front end, which you would be raping from it anyways, why not just use the blue one ? I mean i'm not there to actually compare the two, but from pics bluey looks better off. And you don't have to deal with the huge problem of aligning it back up.SundanceKid wrote:Yes tobIE it is, and it's not all that bad, 400 to straighted the front end out (frame rail mostly) and then get a new front end off my blue car welded on, my dad did a good job drillin gall the spot welds. Before we get the front done though we need to replace the two rockers($1000) so when they put it on the machine to get it streched they have somethign to clamp on to. Then we need to sand and paint and get some decent fenders.....
- ///FiveOneOh
- ///FiveOneOh
