I am doing a KA24DE swap into a '73 dime and the fuel tank only has one nipple on it. So, accommodate a fuel return line...instead of pulling out the tank and welding on another fitting, I added a small tube to the fuel filler neck.
Returning fuel will enter the tank this way. No tank removal necessary.
The rubber hose will direct the returning fuel to the bottom of the tank, and the hose clamp on the end will keep it on the bottom, so there is no "waterfall" sound happening.
For some reason Realm is cropping the images, here are the direct links:
http://img829.imageshack.us/img829/6987/dsc8637.jpg
http://img826.imageshack.us/img826/9352/dsc8638.jpg
Easy fuel return line for EFI systems
Re: Easy fuel return line for EFI systems
Very clever idea, I like it.
