can 280zx rear brak brket b used on 510
I've got a set of rear disk brakes for a 280zx.can I use the factory brake bracket for the 280zx to mount the rear brakes on my 510? the bracket itself is a seperate piece of metal that is welded onto the rear hub. I have a set of 200sx rear disk brackets and they look very similar,in shape.couldn't I mount it on the 510 hub the way its mounted on the 280zx hub?I'm trying to get the swap on with what I have in 280zx parts.
- thisismatt
Re: can 280zx rear brak brket b used on 510
Sure, if you have the ability to cut it off and weld it on competently.
I'm your huckleberry.
Measure twice, weld once.
