Stock headlights just went out! help me please
ok i just picked up my first 510 and i must say i love the car...i was coming home last night and the headlights worked fine...then this morning i was off to school and went to turn them on...and nothing...only my corners lit up...can someone just give me a list of things to check? thank you
Re: Stock headlights just went out! help me please
Ever owned a car before?
Did you check the fuses?
richard norrish
Fuse box would be a great place to start. It's under the hood and subject to the elements, so it can be an issue depending on your location.
Do you have a test light that you can verify power with?
Also, the plugs at the headlights themselves will always be energized if it's stock wiring. However, if you car has been modified (as your handle suggests) then anything is possible. Lots of guys who work on cars have no idea what they are doing when it comes to electrical systems, so modifications are usually a step backwards in engineering.
Fuses
Wiring
Headlight switch
Headlight relay
Headlights
It would help if you clarified your symptoms. Do you have taillights? Blinkers? High beams?
Wiring
Headlight switch
Headlight relay
Headlights
