- mattyhacks71
Fresh head gasket, L20b cam, fitted new carbs and intake mani
Very clean!
And it'll sound awesome above all510wizard wrote:Very clean!
... While working better too of course.
NICE!!
Don't forget that battery hold down on the fuse box...
Say, I'm doing something similar to my L20B and have a question.mattyhacks71 wrote:Fresh head gasket, L20b cam, fitted new carbs and intake mani
Do you have a clearance problem between the rear most carb and the bleed nipples of the master cylinder? Can you get velocity stacks and/or a K&N air filters on the rear carb? I cannot get a short K&N filter on the rear carb because the bleed nipple sticks past the filter element so I can't install the cover. So I am looking for a 3/4, 15/16, or 7/8 master cylinder (for front disc brakes) with the bleed nipples on the outboard side. I have the same Cannon manifold, isolaters and Weber DCOE carbs.
Plus, I am converting the goofy push/pull rod linkage to a cable. I got a 240SX pedal from ebay and new cable from Nissan. The bracket holding the cable on the front carb is just a prototype. Had to fabricate an adapter plate to move the pedal mounting up 3/4" from the stock location to get the cable end and pedal rod to line up. Then had to put in a longer bolt for the pedal stop. All prototype 'cause it needs to be beefed up a bit. And I think I may have to bend/straighten the gas pedal rod a bit to move the gas pedal further from the brake pedal and down. Although it seems ok as is for a heal/toe maneuver. We shall see once I get it running.
Some pics:
- McShagger510
You could cut the nipple off right after the nut and then make a little wedge for where the master cylinder bolts to the fire wall. Doesn't have to be much, just enough to swing it outa the way. The plunger for the master will be fine for a little 1/8" wedge. I think I made mine from a chunk of cardboard.
'91 Nissan truck *SOLD*
'02 TOYOTA Tacoma
'02 TOYOTA Tacoma
In addition to what James suggests, you may also want to dimple the air filter cover by placing it on the end of a socket to create an inward dimple with a ball peen hammer. Sorry no pictures, last time I did this was around 1986.
You can get new master cylinders with the bleeding nipples on the other side ... not sure which year, but my 7/8ths master has bleeders on the other side
- McShagger510
Yeah that's true, never really understood why that was.....indy510 wrote:You can get new master cylinders with the bleeding nipples on the other side ... not sure which year, but my 7/8ths master has bleeders on the other side
'02 TOYOTA Tacoma
'02 TOYOTA Tacoma
Gave it it's first bath in at least 3 years. Maybe more.
Nice!
Is it completely stock? Or a sleeper?
Nice!
Stock with an auto(for now). Though a sleeper would be sweet.abisel wrote:^^^^
Nice!
- mattyhacks71
Here are the ones I picked up from Eurocarb http://www.dellorto.co.uk/product-categ ... -trumpets/abisel wrote:Say, I'm doing something similar to my L20B and have a question.mattyhacks71 wrote:Fresh head gasket, L20b cam, fitted new carbs and intake mani
Looks like you have a ton of clearance. Are you going to mount a K&N filter? Also, I see your MC has the nipples on the outboard side. Can you tell me the MC brand and size?
Made it run! Took a little tinkering and coaxing but she roared to life and idled after a long slumber
