L18 Piston ID
Re: L18 Piston ID
Post by datzenmike »
Ok remembered it wrong.... The '74 620 had an L18 5 bolt crank BUT the flywheel was for a 225mm clutch/pp.
Dimebag
Re: L18 Piston ID
Post by Dimebag »
from the Holy Book of Datsun...
John Thiessen
72 Wagon
Re: L18 Piston ID
Post by 510rob »
datzenmike wrote:Ok remembered it wrong.... The '74 620 had an L18 5 bolt crank BUT the flywheel was for a 225mm clutch/pp.
That's the ticket!
All of the production L18 cranks had 5-bolt hubs, except for the "Nissan Comp" cranks which had 6-bolt hub, with larger bolts on a larger bolt circle than the standard 6-bolt crank hubs (L20B, Z20, Z22, Z24)...
