lostforawhile wrote:so what year would these have been off of? I assume if they are sss carbs i'll just have to go to my original plan of rebuilding them from the nissan motor sports catalog with Z Su parts.
The didn't come on US 510s, so there's no year. Similar carbs came on US 1600 Roadsters, but not all the of the parts are the same.
Not many of the Z SU parts fit the 38s outside of the float bowl stuff, which you already have.
lostforawhile wrote:can they cross reference nissan part numbers to order my parts at Z therapy? i figure the exploded diagram of the carbs will help a lot. these carbs seem to be in pretty good shape, even the linkage is tight and unworn. probably mostly gaskets and other parts,and possibly throttle shafts. I am considering z therapys ball bearing throttle shafts.
You can make the gaskets yourself with some gasket paper, a template, and an X-acto knife. But it's not like they're expensive from ZTherapy.
Virtually everything but the linkage kit is NLA from Nissan. They're not in the business of supporting the old stuff like that, and only old-timer parts monkeys are even going to know what you're talking about when you start of the sentence with "SSS SUs, you know, like on the 510?"
ZTherapy will have no issues supplying whatever it is you may need.
With regards to the throttle shafts, it's not so much the shafts themselves that wear, it's the bushings in the OE carb bodies that wear.
