Cam timing effects on compression
Re: Cam timing effects on compression
Post by datzenmike »
vgwagon wrote:
datzenmike wrote:If 61 degrees should give a cranking compression of 215, and knowing that increasing the closing degree lowers the compression, I assumed that maybe you are advanced one tooth (or 9 degrees). I was hoping that 70 degrees would drop it to 160psi and that would prove to be your problem.... Oh well.
What about retarding the cam a tooth and trying it? Cheap and easy to do. If it improves, maybe try another tooth until power drops off. Then fine tune it closer by advancing/retarding one 4 degree hole on the sprocket. Each hole is almost 1/2 a sprocket tooth.
You expect 160hp? So you are down about 50%... nothing to loose by trying.
That is impressive to make that call over the internet. You are the "L" master zen.
Well thanks Dennis, but don't let Hainz hear you. :mrgreen: I envy you guys building this stuff and running it. I spend way more time thinking about it than actually doing.
Post by defdes »
That's good, the world needs more thinkers....now get off your brain and start building.
Post by 510rob »
you guys build it, you guys talk about it, you guys think about it, I just talk shit about it. :mrgreen:
Keith, is that 145WHP, BHP, or AHP?
Post by bertvorgon »
That would be on the engine dyno, my assumption was that is what was used, not a chassis dyno. Of course it could be like Rebello's dyno......
Post by defdes »
The guy I go to has a "Dynapack" chassis dyno, rear wheels come off and are plugged into the machine using splined adapters.
Yellowcar
Post by Yellowcar »
It's always a nice feeling to get something like that fixed, glad you didn't have to tear the whole motor down. I built a motor for a guy and was trying to figure out why it didn’t run right. Eventually I figured out that the cam had been ground wrong and while the marks all lined up right the timing was actually retarded. I should have degreed the cam rather than relying on the marks…
banzai510(hainz)
Post by banzai510(hainz) »
I say 118 -125hp at the wheel!!!!!!!!!
Post by defdes »
:cry: ^^^^^^^^That's cold^^^^^^^^^^^ :cry:
banzai510(hainz)
Dereks car had L18 with FI and if I remeber correctly he had 118hp
I'm going to go with Banzai, on that type of dnyo, maybe even squeek 130 out of it.
135-145.
Post by defdes »
We have a winner!!!!
I actually pulled a 141.3, but I think this was the best overall AF ratio, torque etc..
40 HP and 20 lbs torque costs 5K...now I know.
defdes wrote:We have a winner!!!!
datzenmike wrote:135-145.
OH YE OF LITTLE FAITH!
