Battery ground cable location
I bought a 510 and the battery was located in the trunk and I am putting it back in the stock location and I was wondering where the battery ground cable attaches to in the engine compartment.
Re: Battery ground cable location
Personally I'd leave the batt in the trunk on passengers side at 1/4 panel for weight distribution and more space in the engine bay but its your 510. Ground the batt under the hood to the starter securing bolt.
I like to run the ground to the magic bolt hole on the head were the lifting hook should be. then a ground strap from the top starter bolt to the top steering idle arm bolt and a second small ground from neg to captured nut on passenger strut tower.
Hard finding top post batteries. The last one was top and side and as our work truck was totaled I swapped for a year old side mount. For $10 at the wreckers I got both factory GM cables from a Pontiac Lumina van. It was FWD and the starter is on the front. Positive and negative cables reach all the way from the right to left side with the ground on the starter bolt. Put it on mine and wrapped with split harness covering. The cables are unbelievably thick. The negative cable also has a molded in body gtound which most replacement battery cables you can buy don't. It bolts to a lug under the battery box.
The smaller ground to the body is thicker than my original negative cable!!!
Ground on starter bolt and look at the thickness of the positive cable!!!
Thanks for the info. Next question is do the terminals face the passenger fender or do they face the engine?
Face the engine. Positive to the front.
What does the stock battery hold down look like?
Here's the e brake...
It you’re redoing the wiring, spin it around though. The top of the post gets pretty close to the hood. Or be sure you have a good boot covering it.
richard norrish
The hold down is a metal rectangle. Held down by 2 jrods. Usually they are rusty by the positive post.
- IMG_20200722_084010549_copy_612x816.jpg (75.76 KiB) Viewed 3005 times
You’re fricking killin’ me Mike...
I had ‘t laughed that hard in weeks!
Thanks.
You forgot bailing wire and duct tape hehehe.
Having been a "TECH" inspector at a ton of Solo events, I have seen every variation you can think of holding 510 batteries in place....holding being a loose term.
Bungie cords were of course the go-to hold down.
Over those years I saw where the "J"-rod had hit the hood at some point, frying the paint and harness.
We once had a fellow roll up to tech inspection and upon opening the hood, found that the battery had tipped over and jammed against the fuel pump......By the time we went through the whole car, it was deemed unsafe to Solo!
It's funny because not only is it true, it's something all Datsun owners can relate to.
I never did figure out a tie down for my 521 battery in the mid '70s. Went around a corner and everything shut off. Pulled over and the truck is on fire. Popped the hood and the battery is beside the engine mount on it's side and burning plastic electrical tape. I get the battery righted and small fire out but it's smoking. I get back in fire it up turn on the lights (2 AM) and..... the gas pedal won't move. The positive battery post touched the body sheet metal and as most suspension parts are rubber mounted, body to frame, the only path to ground on the engine head was down the throttle cable heating it like a toaster. When shut off, the plastic cooled and welded the cable solid. I set the carburetor on the fast idle cam and started for home 15 miles away. Just outside of town the OPP pulled me over lugging along in 2nd gear on the shoulder. It's 3 AM now and I'm almost sober. He heard my story and offered to follow me the rest of the way and I politely declined.
