EGR taper plug?
EGR taper plug?
Apparently Nissan made a plug for the EGR that fits a few models, pn is 14052-21R00. Anyone know if this is a currently available part? I'm not having luck doing a web search.
Ugandan Proverb
76 620 Full custom/resto-mod
Ugandan Proverb
Re: EGR taper plug?
This appears to be for plugging the EGR tube hole on the exhaust manifold... for countries not requiring EGR?
Used on '84 and up S12 CA20 and '86- CA20E on the Stanza exhaust manifolds. Also the 2000 Maxima VG33DE exhaust manifold.
Re: EGR taper plug?
It is a limited availability item, none found locally to me so I ordered one from US supplier - more cost in shipping than the part.
Apple (?) Nissan in Richmond(?) apparently has one in stock if anyone looking for such, and a few in Ontario.
Ugandan Proverb
Ugandan Proverb
Re: EGR taper plug?
would that be a BSP fitting ?
Re: EGR taper plug?
I have no EGR on my L20B and the TVV was broken and unused so I deleted it and used a core plug from a KA intake I had laying around. They are on all kinds of later engines in all sizes and not hard to find. Take an Allen set with you.
Re: EGR taper plug?
JIS Tapered Pipe spec is the same as BSPT spec
Re: EGR taper plug?
Not the same thing, this is a much larger diameter and machine thread.
The right part fits very nicely.
Ugandan Proverb
Ugandan Proverb
