S13 Suspension in a 510
Re: S13 Suspension in a 510
Finished up the framework in the rear and on of the wheel well tubs. Moving at a feverish pace now. Less than a year since the last update!
- tub.jpg (295.14 KiB) Viewed 4437 times
Why not a VH45? Or a VK56? fun build to follow for sure!
My friends did a lot of 1UZ swaps in other cars so I just kinda followed them. The engines are cheap and a lot out there. I got a whole 2001 GS430 that was totaled for $1400 so the deal was a no brainer. I would prefer it to have a Nissan but oh well.
I started working on the driver side wheel well today. I used 22 ga sheet metal 2'x4' from Lowe's. Not the most economical choice. I made a sheet metal bender out of 2"x2"x.0.25" angle iron. I would not recommend building one. It took me a few tries to build one that works.
I marked off the sheet metal in 1/2" increments to know where to use the metal shrinker from harbor freight. I started from the center and work outward until I have the desired curve. I used an air cylinder to power the metal shrinker, but i think they make a stand that has a foot pedal.
- 20190914_092019.jpg (255.12 KiB) Viewed 4251 times
starting the curve
- 20190914_095513.jpg (410.74 KiB) Viewed 4251 times
almost there
- 20190914_153119.jpg (479.52 KiB) Viewed 4251 times
used a template to measure the radius.
- 20190914_165558.jpg (388.19 KiB) Viewed 4251 times
Finished product
- 20190914_165838.jpg (561.91 KiB) Viewed 4251 times
Great job!
I cut the wheel well opening to big before when I was going to use BRE flares. I had to patch the metal and then cut it to the right opening. next step is to make the flares out of metal like the other side of the car.
I didn't like the position of the engine mounts on the modified skyline cross member. The engine sat too far forward and the weight distribution was really bad. I chopped up a s13 cross member and move the mounting pads back. I welded it up and forgot to take more pics before I installed it. So below is like the halfway point
I bought GTX2 LCA and tension rods from Techno Toy Tuning. They are pretty Beefy.
I moved the cross member back a few inches to push the engine back even further. I put some plate on the top and bottom to beef it up
Cut out what was left of the firewall to let the engine slide back.
