S13 Silvia Coilovers on a 510...
I have a set of old s13 coilovers with camber plates kickin around. Has anyone modified a set onto there 510 ? If so whats involved ?Looking at either doing s13 conversion if its somewhat easy or just going with the full techno toys setup. Thanks.
Re: S13 Silvia Coilovers on a 510...
It's been pretty well documented here.
http://www.the510realm.com/viewtopic.ph ... +coilovers
If you wanted to start fresh, I'd recommend a weld on setup for an AE86 since that chassis is light like a 510 and it uses one-piece struts so the motion ratio and damping should work pretty well in a 510. The AE86 damping would likely be better than S13 for the reasons stated above.
I would steer clear of trying to graft 2 piece S13 struts to a 510 and leave it as just s13 coilovers mounted to 510 or zx or s12 etc struts of your choice.
Hope that helps a bit.
