2.3L of fun
- funwithmonkeys
2.3L of fun
I bought my first 510 a month ago after years of drooling over them. I have plans for her one little thing at a time.The first thing I did was put in a weber 32/36 carb. It made a huge difference in the way it drives. It really brought the car to life. this weekend a took care of a couple of small items...new hood release cable and antenna and got a autometer tach ordered from Lordco. There are lots more parts on the way already but they will be put in over the next few months so I have some projects for the weekends and get a chance to feel the difference in the car after each item is put on to make sure the project is going in the right direction.
- funwithmonkeys
Re: It begins with the small stuff
here she is the day I brought her home
- 40.jpg (199.47 KiB) Viewed 14080 times
- IMG_00000989.jpg (231.55 KiB) Viewed 14080 times
- IMG_00000988.jpg (625.88 KiB) Viewed 14080 times
- funwithmonkeys
The New weber installed and running great
- IMG_00001132.jpg (677.99 KiB) Viewed 14080 times
- funwithmonkeys
This weekend I got to a couple of little bits that needed doing. Cleaned up some messy wiring, installed an Autometer 2 5/8" tach and replaced the sketchy battery cable.
Next weekend the old girl will get a new rad.
- IMG_00001148.jpg (637.78 KiB) Viewed 13949 times
- IMG_00001149.jpg (599.44 KiB) Viewed 13949 times
- the new tach installed
- IMG_00001150.jpg (636.82 KiB) Viewed 13949 times
- funwithmonkeys
Its been a while since I've posted on my build. I've done a bunch, Just haven't had time to take pictures and post about it. I'll get to the pictures when it stops raining one of these days. I now have a 3 core Champion rad with electric fan, Troy Ermish long tube ceramic coated header with 2" exhaust and a disk brake setup on the rear. This weekend the old girl is finally getting a 5 speed put in with aluminum flywheel and stage 1 ceterforce clutch. Hopefully in the next couple of weeks I'll get the techno toys lower control arms, camber plates and coilovers with the 200sx struts and 4 piston volvo calipers put on.
Please rid your self of that fram filter. Get something like NAPA gold or Wix. Fram are only good for masking the oil filter boss when painting the block.
- funwithmonkeys
It is on the way out, I have to put on a new oil pan gasket and am waiting till I do that to change the filter and oil.datzenmike wrote:Please rid your self of that fram filter. Get something like NAPA gold or Wix. Fram are only good for masking the oil filter boss when painting the block.
datzenmike wrote:.... Wix. Fram are only good for masking the oil filter boss when painting the block.
Maybe you weren't finished when you took the pictures..I'm sure that's the case, but, I don't see a vacuum line from the carb to the distributor. Or, a vacuum cap plug on the carb.
- funwithmonkeys
the vacuum line comes off the passenger side of the carb and there is a plug on the drivers side. I couldn't remember doing it but apparently I did.bertvorgon wrote:Maybe you weren't finished when you took the pictures..I'm sure that's the case, but, I don't see a vacuum line from the carb to the distributor. Or, a vacuum cap plug on the carb.
Very clean 510 indeed, nice buy!!! If you're interested, I have a very clean non cracked and straight OEM top dash to replace your cracked one.
Lou
Lou
- funwithmonkeys
I may be interested in it. I was thinking about doing something about it in the spring. Let me know what you want for it and maybe we can work something out.Three B's Racing wrote:Very clean 510 indeed, nice buy!!! If you're interested, I have a very clean non cracked and straight OEM top dash to replace your cracked one.
Lou
Great looking car. It's a '69 for the most part, but missing the rear round quarter lights. Is there evidence of the holes being welded up in the inside of the trunk? I've always liked the look of those wheels on a 510. Nice color too. Great find!
It's got most of the '69 bits...but that fuse box isn't. Strange mix. Fuse box is NBD, could have been changed out, but the lack of rear marker lights would have taken a bit of work.
