Location is Tacoma WA,
I sold my 510 wagon some time ago, and now am also selling all my parts.
Parts have come from all over, some are 510 stuff, some 620, some 200sx, and the rest who knows.
most of the 620 stuff is from a 78 or 79 620 I parted out that had bad front end damage.
the 200sx stuff is from a 81 200sx I temporarily saved from some scrapers to get parts off of, Wiring was gone when I got it so I wasn't able to see if it ran, I suspect the head gasket went because I carefully took apart the engine, and now the #4 cylinder has light surface rust, but the other 3 dont have any rust.
Some of the parts I picked up while buying actual parts I was needing at the time, or I decide to use something else.
Here is a link to my Photo buck album so see the pictures of what I have.
http://i1210.photobucket.com/albums/cc4 ... rts008.jpg
Prices are firm, unless you you think I am just asking to much let me know. (would consider trade for Suzuki Samurai related stuff)
And if you buy all of it at once I will give you a package price at $800 and my wife will buy you a 6 pack.
I didn't price all the small stuff, if their is something you see you want let me know and we can figure out a price, if you are buying stuff I will probably just let you have it.
I also have a "mobile parts shed" aka 4x6 enclosed trailer I will also be selling, but first need to sell about half of what I have as that is where it is stored. The trailer is not a looker, but doesn't leak, and tires are great shape.
620 drive shaft short
$15
620 drive shaft long
$15
200sx drive shaft
$15
510 Wagon rear axle, H190 3.90, with new break stuff, and bearings
$120
Truck H190 3rd member with 4.375 gears
$50
510 strut assembly sale pending
$15
510 front break calipers
$15
510 front break rotors and pads, New.
$30
200sx rear break calibers
$15
4 speed tranny(short shaft), synchros are will need to be replaced
$30
5 speed tranny (long shaft) came out of a 620, but I don’t no if it was originally from that truck, unsure of condition.
$80
620 Intake and carb. Carb needs to be rebuilt badly, and intake emissions stuff removed or plugged. Pending Sale
$25
Matchbox Dizzy (unsure of condtion, looks good, never put it to use) Sold
$30
620 non-Matchbox electronic dizzy Sold
$30
38mm SU, for parts. One carb body has a crack at the flange, and one of the needles is in bad shape, other then that they are complete
$40
Z20E short block disassemble(can be used for L20b block with some work), main caps are in the correct position. Long Connecting Rods are N8500 @ 152.45mm with the corresponding short pistons. rods and pistons sold
$100
Z20E Head, assembled
$25
Head W58, round port, Open chamber, ran when replaced with a 219 head
$50
Head 210 casting, not all the valve train pieces their, condition unknown
$20
3 L20b connecting rods
$10
4 L20b Rods and pistons
$40
L18 short block with Fly wheel. Ran when pulled. sold
$100
L16 Short block
$50
L20b long block, front cover cracked from me dropping it, U67 head. Condition is uncertain, The Guy I bought it from was told that it ran. Head is a U67, reground cam
$100
L20b Fly wheel, 6 bolt 225mm Sold
$20
Z20 (same as L20b) Flywheel with clutch, 6 bolt 200mm Sold
$30
Valve cover with thick textured black coating
$20
z20e starter
$25
Starter from L20b
$25
Alternator #1 ???
$10
Alternator #2 ???
$10
Z20E (nap-Z) Exhaust manifold
$15
L20b Round Port, Exhaust Manifold
$15
Exhaust Header, square Port
$60
280 Z seat no rails
$5
280 Z seat no rails
$5
300zx seat with rails
$5
620 head light frame set
$5
Lots of parts of Random parts from 510 wagon, 620, 200sx, L
- crazytimme
- DatsunTech72
Re: Lots of parts of Random parts from 510 wagon, 620, 200sx
Email me at : fomocokid3024@verizon.net I'm interested in some of that good stuff!!
