Suspension Setups
- PoorMtnKid
Re: Suspension Setups
Thanks for the info. Now I know that going that high is not necessary. I was thinking 250 275.
175 in/lbPoorMtnKid wrote:but am unsure of the spring rate I would like to use. I'm mostly going to use the car for drives to and from work in the winter time and for weekends when I go to the disc golf course. I would like something with a little cush. Any input?
Really, all you're going to get for replies are what other people are running, and that'll be the gamut of spring rates. Best bet is to find another 510 that's been swapped and has higher-rate springs, take a ride, and see what you think.
I ran 175 rates in my KA510 and personally wouldn't go stiffer. Lots here have mid 200 rates and wouldn't go softer.
- PoorMtnKid
That is excatly what Im looking for though, peoples personal expierences. I know its not gonig to be what I want. But its going to give me an idea. And also their are not to many 510's in my area. I know there is one guy with a 4 door KA so I would like to see what he has. Hopefully he knows what spring rate he has. With one guy saying he had 350's and they are too stiff. And you said you have 175 and would not go stiffer, at least I have a good range. I just did not want to get something too soft and the motor be too heavy. Not sure if thats even possible but thats why I made the post in a already huge thred and not make a new one lol thanks though.
KA is heavier than an L16, that's for sure. But stock 510 spring rates at ~90 in/lb, so the 175 is already almost double. It has more to do with desired ride quality, driving style, and road conditions than engine swap weight...at least L16 --> KA.
If you are going to have coilovers front and rear, changing rates is relatively easy, and you could experiment with little cost since you could likely sell the spring sets on again if you don't like a particular rate.
so i ordered a GC coilover weld on kit for my 280zx struts.. it says on GC web site i can use the stock shock? anyone else using this set up? everyone else i see is using different inserts? im kinda low on funds at the moment...
- thisismatt
It's doable. They are an open bath design, so you can open them up and change the shock oil to something heavier to increase the damping. That is if the shocks aren't worn out.doughboi916 wrote:so i ordered a GC coilover weld on kit for my 280zx struts.. it says on GC web site i can use the stock shock? anyone else using this set up? everyone else i see is using different inserts? im kinda low on funds at the moment...
I'm your huckleberry.
While the bump/rebound ratio stays the same as stock, you can up the oil viscosity. Use the same volume as recommended, go to a motorcycle shop, to get FORK oil ( Belray is one brand) , and you can try 10W or for even firmer, try 20W. WAYYYY back..I used 20W in my stock shocks, for solo use.
man.. my head hearts Ive been reading for a few hours.. going through build threads... and i read different things about using different strut inserts.. ive read and been told that the both KYB AGX and Tokico Illuminas for the 280zx have been discontinued..???? i dont want to use the mr2 insert cause i dont now how to shorten the strut??
- thisismatt
There are likely alternatives that are close enough. Shorter inserts can be spaced out inside the strut tube if necessary.doughboi916 wrote:man.. my head hearts Ive been reading for a few hours.. going through build threads... and i read different things about using different strut inserts.. ive read and been told that the both KYB AGX and Tokico Illuminas for the 280zx have been discontinued..???? i dont want to use the mr2 insert cause i dont now how to shorten the strut??
- Dave Patten
That must be just recently, I ordered a set of BZ3038 Tokico Illuminas (280ZX) from Lightning Motorsports begining of September for $111.40/each with free shipping.doughboi916 wrote:man.. my head hearts Ive been reading for a few hours.. going through build threads... and i read different things about using different strut inserts.. ive read and been told that the both KYB AGX and Tokico Illuminas for the 280zx have been discontinued..???? i dont want to use the mr2 insert cause i dont now how to shorten the strut??
http://tinyurl.com/Tokico-BZ3038
Anyone have the Illumina 5 way adjustable part number for rear coilovers?
contact benzo here, he sells/gets tockico for a good price;)defdes wrote:Anyone have the Illumina 5 way adjustable part number for rear coilovers?
Front: 280ZX struts, Z31 5-bolt hubs, 200lb spring on coil-over perch, Illumina insert, custom camber plate with fixed offset for more caster. Late (70-73) LCA’s w/ poly bushing (double-sheer fixture added to LCA pivot bolt) and poly T/C bushing. No Sway bar (yet) 1st gen. MR2 rack&pinion steering, 1” bump steer spacer.
Rear: Ermish QA-1 non-adjustable coil-over shock, 200lb spring, re-drilled 510 hub to 5-bolt. Slotted rear cross member, no sway bar.
I need advice in choosing the front sway bar rate. Because I moved my motor back a bit, I can’t use any of the front 510/SR sway bars that are available, so like everything else I have to make a custom one. It’s easier and maybe cheaper to go with a “speedway” style 3-piece sway bar, plus I’ll be able to tune with different bars if I choose. Can anyone offer any advice on which bar I should choose to start with. I’m going with a 1 1/4 diameter hollow bar because this is a common size and there are many rates to choose from. From Speedway I can choose wall thicknesses of .095, .120, .188, .250, and solid. There’s a rate chart here if anyone has a way to offer a rate comparison to the bar your using in your car. My thought was to start with the thinnest bar and go from there. Any other thoughts?
Maddat makes a front sway bar that goes forward and will clear any engine set up I can think of.
http://www.maddat.com.au/products/SWB1600.htm
I'm using one, it's a nice piece.
Anthony
'71 wagon, 2jz-gte engine, other stuff
http://www.cardomain.com/ride/674663
Well I got a set of 280zx struts or was told thats what they were from a 81 280zx. Here are pictures just making sure I did end up with 280's
Thanks guys
Thanks guys
