I am looking to repaint my 72 datsun 2dr and i remember seeing color codes posted on here a while back but can no longer find them. The color is orange but i cant recall if there were more than one color code for orange. Would anyone know or could provide the color code for orange?
thanks.
datsun 510 color codes
Re: datsun 510 color codes
Do you know the number? It is stamped in the top of the radiator support (next to the female part of the hood latch).
You might try here...
http://www.automotivetouchup.com/choose ... l%20Models
- datsun_paintcodes.gif (21.16 KiB) Viewed 10062 times
no, i couldnt find anything of the top of the radiator support. The web site shows three orange colors. It's a start. Which orange was most common for datsun?
Here's what I have...
Hope it helps.
EDIT - Colour chart now higher resolution
Hope it helps.
Did your car originally have a white interior? I will take a pic of mine so you can see if it is the same - and I can give you my paint code.....
This is the other orange (burnt orange).
yes, the original interior is white. here is a pic of the color of my car. There not the best pics but you see the color.
bryon, what is the orange color code in the first column third row from the bottom? 092? Can't read the numbers. thanks.
That would be Paint Code 022
I'll see if I can download a higher res pic of that chart.
EDIT - Ok if you double click on the paint code chart in my above post, you should get a much larger hi-res picture now.
Thanks Byron, I'm pretty sure that the color code of my car. Thanks.
