KA with stock Tach (IT WORKS!)
Dimebag
Re: KA with stock Tach (IT WORKS!)
Post by Dimebag »
Hey, right on - I'm glad it all worked out for you! nice work with the splices.
John Thiessen
72 Wagon
DMS
Post by DMS »
I have a little experience with the Nissan Ignitor systems. Alot of the Nissan tach circuits with an ignitor in the circuit as the signal have a resistor in series on the neg signal wire from the coil.
i cant remember if the 240sx engines had the same thing. I know that the older VG30 vehicles and 280zxt systems had this resistor for sure. Its been along time since I touched one of those systems and cant remimber, but i think the resistor is just there to drop the voltage... which means you might be able to burn up your tach. Its located under the driver side dash in most vehicles and is usually forgotten when everything else gets pulled. Just some extra input
Dimebag
Post by Dimebag »
The resistor you are talking about is shown in the wiring diagram. Considering the way the stock tach measures "flyback impulses" on the positive side of the coil, I don't imagine it could be burned out by this resistor.
John Thiessen
72 Wagon
DMS
Post by DMS »
I meant if you didnt have the resistor in place.
Post by 510rob »
The white wire going through the tach is exactly that - a wire passing through a pulse transformer. In plain english, that means the tach is electrically isolated from the ignition circuit. That can be taken one step further to say the current limit of the system is based on the heat capacity of the wire+insulation of that white wire & the pulse transformer...
inline4
Post by inline4 »
I'm having a hell of a time getting this to work, am I that dense?
Dimebag
Post by Dimebag »
ok, quick review.
1 - Identify connector F30 - it is a two-wire connector on the bottom of the 240 coil next to the high-tension coil wire that goes to the distributor.
2 - the two wires in connector F30 are color coded. The one you are interested in is B/R (black w/ red stripe)
3 - you will need to cut that B/R wire and splice the two white wires from the factory tach to each end of the B/R wire you just cut. There is a great picture showing this with blue splices.
4 - Don't forget that the factory tach itself has a power wire that needs to be hooked up.
5 - as per the previous instructions, if you think you have it all hooked up correctly and it doesn't work, try swapping the ends of the the two white wires where they are connected to the B/R wire.
good luck.
John Thiessen
72 Wagon
inline4
Post by inline4 »
I only have the three wires coming out of the black grommet.
I dont have the two white wires. am I missing something?
Dimebag
Post by Dimebag »
inline4 wrote:I only have the three wires coming out of the black grommet.
Are you hooking up a factory tach? That's what these instructions are for. If you don't have the two white wires, then I'm guessing you have something else.
post of photo of what you do have.
John Thiessen
72 Wagon
inline4
Post by inline4 »
Dimebag
Post by Dimebag »
hmmm, interesting. Here is what an unadulterated factory tach looks like.
Maybe yours was 'modernized'. Are your wires labeled?
John Thiessen
72 Wagon
rnorrish
Post by rnorrish »
there is definitely something missing there! :shock:
richard norrish
inline4
Post by inline4 »
peering inside, there seems to be some resistors soldered in. this tach worked when i had the L16 in the car, I just don't particularly want a dead gauge. it had 2 wires running to the coil, and one attached to one of the wires behind the dash.
I also had I believe some type of hitachi electronic ignition?
arkitekz
Post by arkitekz »
Your right Inline, your tach seems to be in different condition than mine. You may have to chime one of the electrical gurus in here to help you figure it out.
