Thanks for the comments Byron. I miss Shasta, been going to the Motoring J show instead.
Yeah, rear mount as in under the floor, probably all the way in the back. My biggest concern is cooling under heavy load and ducting air there. I could run a Taurus fan which pulls some ridiculous cfm, something like 3500-4000. But the current draw is so high you have to run special relays etc. so I'll probably just run the fan I have for now and see what happens. I know wagons have a huge vacuum at the rear, be nice to utilize that somehow.
With the bumper, radiator, intercooler, and one of the oil coolers off the front end it actually raises a bit, the tire to fender gap is noticably larger. The only thing I'm putting back is an air to air intercooler, piping, and a much lighter airdam so this should help my weight distribution a bit.
Not mine Wagon+Toyota=
Re: Not mine Wagon+Toyota=
Anthony
'71 wagon, 2jz-gte engine, other stuff
http://www.cardomain.com/ride/674663
Have some time off so I'm trying to get this thing running this week. The biggest hurdle will be the plumbing of the radiator from the rear. I'm about 1/2 done with that, the bracket for the radiator is made.
I installed leaf spring sliders to replace the shackles in the rear. We'll see how much differece it makes, but from what I've read I thought it would be worth is and I got a great deal.
Got tired of working on the rear so went to work on getting the air to air intercooler installed and making a new pipe. A lot of small stuff left up there but these pix give a good idea of things. Turbo inlet pipe will be covered with heat insulation at the least. Tight fit in there. Anyway--pix.
Anthony
More pix
Anthony
- thisismatt
They can, but it's more the angle of the pic. They are not in negative arch despite what it looks like. The sliders are in the same place the shackle was originally and allow the rear of the spring to slide backward and keeping the roll center constant as opposed to a shackle
Anthony
