by Byron510 on Tue Feb 24, 2009 3:32 pm
The alignment is really important with any lights. If you have checked yours thoroughly, then that is good. But I have to say that many people, when installing auxiliary lights, do not properly check alignment. The statement wasn't an attack, but simply a statement from a guy who spends a lot of time on the road, and have been blinded by many an auxiliary light.
The new projector style lights are very focused, and do light well to the point that they are aimed. But the light is comparable to a high intensity LED. It's focused at one spot, but overall lighting is not really improved. Have any of you tried an LED shop trouble light? Crap in my opinion, what a waste of money. I’ll take the old incandescent or fluorescent bulb any time over the LED unit. The light is so focused, that no where else gets any light at all, making the positioning of the light critical – what a pain in thhe but when working in confined space like under a dash. Same goes for the headlights. A focused point dead ahead is nice, but I like to see what’s coming from the side, and the ditch, and slightly around a corner to get the full picture. Having driven a whole range of rental cars in the last few years, the one thing that I have noticed is that all manufacturers use a focused beam of some sort - call it what ever you will, Zenon, HID......- but they all have a regular incandescent or halogen bulb for the high beams that supplements the low beams, which just simply stay on. If the projectors work so well on the lows, why are they not used on the highs? I would think that the time it takes an HID light to start up is one reason, but is there another reason? Maybe someone with knowledge on this question could post an answer. More of a question for person knowledge than anything.
I'm all for finding a solution that provides better light in any car. The H4's and H1's that I've loved for all these years are getting harder to find at local auto parts stores, simply because no one is buying them anymore. I collected a rock in one of those age old Cibies on our last Oktoberfast road trip, and that light does need to be replaced. I'll have to do it as a pair as you can't find these things anymore in singles. I'll continue to read on, and if someone finds a good solution that improves lighting, I'm all for it.
