Page 7 of 13
Re: The SSE (Super Sport Estate) Project
Posted: 12 Feb 2012 11:29
by 510wizard
Since the weather here has been unseasonably nice , I rolled the engine outside yesterday to drain the oil and put a new oil filter on. Also did a few other things like remove the power steering pump and some general clean up.
I am going to build an engine test stand , so that I can mess with it, instead of leaning over an engine compartment. Should be a lot easier to get it running. I do have to order some flywheel bolts, since the engine was originally from an auto and the bolts are different for a manual.
Posted: 12 Feb 2012 11:51
by RonM
You take doing it right to a whole new level.
Posted: 12 Feb 2012 12:04
by okayfine
RonM wrote:You take doing it right to a whole new level.
VTOL engine test stand?
Posted: 12 Feb 2012 13:38
by goichi1
I see that FJ hood still needs paint!! I figured you'd be done with that project by now!!
Posted: 12 Feb 2012 13:42
by goichi1
I also remember a video of a guy starting one up on the floor. Looked like it ran smooth and didn't jump around.
Posted: 12 Feb 2012 15:50
by 510wizard
goichi1 wrote:I see that FJ hood still needs paint!! I figured you'd be done with that project by now!!
Yea right, still lots to do to that project too! Now you're making me feel bad about not working on that project.
One thing about the FJ, it's going to be worth something when it done, where the 510's are kind of stuck in value appreciation. But, the 510's are a lot more fun!
Posted: 13 Mar 2012 11:02
by 510wizard
Finished the ECU wiring harness down to the test prototype stage. Hooked up the Nissan Consult lll to the OB2 plug, so that I can program the NATS ( Nissan Anti Theft System). The NATS must be programed to allow the engine to fire. One problem though, the Consult won't communicate with the ECU, rechecked the OB2 plug to the ECU. Checked ok, did notice that the ECM relay not closing. Dam, looks like my long awaited Ebay ECU find is bad. Time to put my 39 years of chasing electrons to use. I found that besides the ECM relay not engaging that the processor in the ECU wasn't running, which is why no communication with the Consult. Traced the circuit in the ECU back to a defective mosfet power switch. Found the same part in the G35 auto ECU, removed it and placed it in the Maxima ECU. Here are some pictures of the part placement in the ECU's. Note the size compared to the pencil tip.
Here's the part installed in the Maxima ECU;
After replacing the part, the ECU came to life, the relay works, the fuel pump runs for couple of seconds like it is supposed to. Next, with my fingers crossed, I hooked back up the Consult to the harness. Success, communication! Finished the programming of the NATS, no more security light. Though the Consult, I can control the fuel pump and watch the changing of the voltages on the throttle pedal when moved. Looks like it going to work. Next up is the finishing of the engine stand and hopefully the starting of the engine. Fingers are still crossed, that there is not any further problems with the Ebay ECU.
Posted: 13 Mar 2012 11:19
by S15DET
Nice surface-mount skills. Great work!
Posted: 13 Mar 2012 11:24
by 510wizard
Thanks, I did notice that my eye's aren't what they used to be. It's a bitch getting old.
Posted: 13 Mar 2012 11:27
by two_68_510s
Always wondered why you were the 510wizard
, great troubleshooting as well!
Posted: 13 Mar 2012 12:46
by goichi1
Holy crap, thats really cool, I repaired a card in an old big screen TV once, it was fun but didn't look as nice as your skills there, but it worked!!
Posted: 16 Mar 2012 23:10
by hang_510
S15DET wrote:Nice surface-mount skills. Great work!
good stuff right there!
Posted: 23 Apr 2012 09:24
by 510wizard
Update: Got the engine stand completed, used steel from an old tread mill and some cheap HF casters. Wanted to be able to roll the assembly in and out of the workshop easily.
JWT flywheel installed, old VG fuel pressure regulator mounted on the intake manifold for test purposes. Found an old metal gas can that I used to use when I mowed lawns in high school, couldn't find a metal can at the stores, all plastic these days. Mounted a fuel pump assembly into it with a fuel filter.
Removed the power steering pump and the air conditioning compressor. Ordered a shorter belt for the remaining alternator.
Wired some LED's for the oil pressure, Mil light, and charge light. Note: key inserted into Nats antenna.
Hooked up the modified harness to the engine with the repaired ECU, programed Nats , electronic throttle,and relays / fuses. Time to cross my fingers and do a little prayer to the engine gods. Please start, oh pretty please.
IT RUNS!!!!!!
Made a little video;
http://www.youtube.com/watch?v=sd-ex-DBthI
This is a major accomplishment for the project. Next up is to make a fuel pressure regulator holder that uses a Bosch FPR at 3.5 bar.
Posted: 23 Apr 2012 09:32
by okayfine
510wizard wrote:Update:
IT RUNS!!!!!!
I know how it feels!
Posted: 23 Apr 2012 13:02
by eoot
absolutely incredible work! Looking forward to seeing the hottest Goon on the planet up and running.
