onslot wrote:looks great is that 1969 camaro lemans blue ?
The paint is just a color I picked from a sample slab. I got it at a local paint store here is Phoenix. I have the recipe for the color if you want it onslot.
true.dat wrote:what tool did you use, to strip it down to the metal like that?
did you remove the windshield and gaskets to paint it? or did you leave it on.
I just used a die grinder with a scratch rite sanding disks. It worked very well.
510Freak wrote:Looking good Rich,Glad to see it going together now, I guess the weather has finaly cooled down there now , cheers Lou
Thanks Lou, the temperature has been staying blow 90 every day now so it’s perfect weather to get out and get some work done.
shwyn510 wrote:hey rv, i just used 2 bolts on the far end of the air dam. and then i used a couple more right before the holes for the brakes. the fitiment will never be "perfect" but with a little time you'lll get it right. most likely you will never be able to mount the middle of the spoiler though.
Thanks for the advice shwyn510 I will definitely try it your way.
Rich VanSickle
04' Nissan Frontier (Daily Driver)
71' Datsun 510 (Getting a facelift, she's vary close to running now)
